A1
| posted on 11/12/08 at 09:52 AM |
questions on design...
got a couple of questions about designing a car...cant decide where to put them?
basically what are the best steps to take after pencil diagrams?
Mr Whippy
| posted on 11/12/08 at 10:00 AM |
if you have a chassis design drawn out I'd recommend you make a model out of balsa wood and make a replica about a foot long to see if you have
the bracing tubes correct, assuming it a space frame or similar. Any weakness in the stiffness of it will be very apparent in your hands and best of
all you can quickly correct any faults and test them for pennies. Something that is difficult to do even on a computer. You'll also pick up the
correct order in which to assemble the real thing
balidey
| posted on 11/12/08 at 10:03 AM |
You could post up your designs on here and then everyone can tell you what you've done wrong
mcerd1
| posted on 11/12/08 at 10:08 AM |
where abouts are you in scotland ?
(or does your user name give it away )
or a 3D CAD model for those of us who can
[Edited on 11/12/08 by mcerd1]
dubstar_04
| posted on 11/12/08 at 10:12 AM |
I would go for a cad model and then some CAE analysis work.
iank
| posted on 11/12/08 at 10:16 AM |
Computer model takes 100 times longer and doesn't show you how stiff/floppy it is - it's truly amazing to find how changing one or two
tubes can make such an enormous difference.
Computer model is the next step especially if you want to make more than one. If it's just for you, copy of the balsa model in steel and drive
it
Anonymous
iank
| posted on 11/12/08 at 10:20 AM |
you need a lot of experience to get useful information out of CAE. Just putting in a model and pressing a button can give massively wrong answers.
Best way to understand spaceframe stiffness is to twist a physical model in your hands. Once you've done that CAE can be made to give a 5
decimal point answer that isn't actually very useful for anything on a homebuilt car.
Problem with computers (and I work with them for a living so am quite biased towards them ) is it takes 100 times longer to do by the time
you've futzed around getting everything just right, by which time you've lost interest and momentum.
Anonymous
Mr Whippy
| posted on 11/12/08 at 10:23 AM |
a real model in your hand tells you far more and quicker than a computer model on a screen
mcerd1
| posted on 11/12/08 at 10:32 AM |
it
that depends on what CAD you've got and how good you are with it
CAD (as in computer aided drafting - eg autocad) is slow and won't tell you much
but a CADD package (computer aided design & drafting - something with static, dynamic and/or FEM analysis) could tell you allot more than the
wooden model and a good one will let you model it quickly
if you can't get your hands on something like that (and the experience at using it) then a balsa model is probably much quicker and easier
when I get the time, I'm going to have a go at modeling up some versions of the book chassis using Tekla / Staad
richardlee237
| posted on 11/12/08 at 10:37 AM |
I 2nd Mr Whippy.
Anyone who has built model aircraft wings will understand the benefit of a model when determining structural stiffness.
I am quite proficient in Autocad but could build a locost model chassis faster then I could draw it and the drawing tells you nothing about torsional
or longitudinal stiffness.
Richard
Quote Lord Kelvin
“Large increases in cost with questionable increases in performance can be tolerated only in race horses and women.”
Quote Richard Lee
"and cars"
A1
| posted on 11/12/08 at 11:08 AM |
im in edinburgh...nah, thats my real name believe it or not!!
cheers, ill try doing a balsa model sometime soon!
mcerd1
| posted on 11/12/08 at 11:23 AM |
so your just up the road from me then
feel free to give me a shout if you want a hand with some cad stuff (once you've got a bit further with your design that is)
A1
| posted on 11/12/08 at 11:29 AM |
thanks very much! wherabouts are you?
mcerd1
| posted on 11/12/08 at 11:33 AM |
Haddington
there are a few of us in and near Edinburgh, we should probably organize some sort of meet again
(I was thinking about karting next year sometime ? )
A1
| posted on 11/12/08 at 11:45 AM |
sounds good! i was thinking of trying to organize a trackday at knockhill or something...
mcerd1
| posted on 11/12/08 at 11:52 AM |
sounds good too, but I've only got a boring car at the moment
(yes I know before anyone says it, get my finger out and build the thing.........)
smart51
| posted on 11/12/08 at 12:17 PM |
Are your pencil drawings sketches or technical drawings?
I'd take some measurements of:
1) me
2) the engine and transmission
3) the wheels, suspension and steering
then draw it out to scale to make sure it all fits.
A balsa model of the chassis is a good idea. I then made a seat and pedals out of plywood and foam to check that there was enough room. Still, I
found that there wasn't space for the master cylinder below the bonnet. The more checking you do on paper, the less you have to redesign during
the build.
iank
| posted on 11/12/08 at 12:47 PM |
My points are
1. It takes an evening and about £5 of balsa and glue to get to a chassis design you've proved is stiff. You just can't do that with any
cad package. Certainly worth doing just to have something sat on your desk for people to ask about.
2. Every 3d cad/modelling package I've used takes days/weeks to learn to use at any speed, and you still won't produce a full chassis in a
couple of hours. I certainly wasn't thinking anyone would use autocad for the job.
3. Just because you've got a software package that can calculate stiffness it doesn't give you the experience to set it up and to be able
to tell what the numbers it's giving you actually mean. All the professional engineers on here who've commented on them say it's
not for amateurs - not saying that you couldn't use one successfully as I don't know how experienced you are, but someone asking what to
use going from a pencil drawing has little chance of knowing what the figures mean and how to make them better.
Finally - and I know most people here don't care in the slightest - to get a £5000-20000 software package for most of us actually means getting
a cracked version from the net for free which means you're breaking the law. At some point someone's going to get caught and paupered by
a legal firm for that.
Anonymous
Mal
| posted on 11/12/08 at 01:12 PM |
For a balsa model, make it at 1/8th scale.
This is convenient because 25mm square rhs can be modelled in 3mm square balsa.
I found it good for accessing torsional stiffness and for working out how joints will be made.
mcerd1
| posted on 11/12/08 at 01:53 PM |
My points are.......
points taken, and basicaly I agree with you
I guess I just favour CADD as I'm crap at woodwork
I recon I could have a go at stiffnes and strength analysis using the structural design packages Ive got at work (but these arn't ideal as they
don't really do dynamic loading )
so just to be clear to A1, when I'm offering help with CAD its really on the drafting / detailing side - with the aim being to produce part and
assembly drawings like the ones in chris's 'new' book
A1
| posted on 12/12/08 at 12:37 AM |
my drawings are technical, only on a4 paper though but done to scale, one from front, back, side and top. not got any decent diags of the chassis yet,
but ive done a few rough sketches...
dont have any measurements for engine/tranny etc, but working on it...
