YQUSTA
| posted on 11/1/09 at 08:39 AM |
Ford Focus cutting out
My mate has a 2001 focus (1.8) petrol.
He says that the engine dies at low rev's even when driving and changes gear it cuts out.
I'm going to see him today so was wondering if you guys had any ideas?
I can think of the easy bits air filter, fuel filter or fuel pump but just wondering if i'm missing some thing obvious.
YQUSTA
jonesier1
| posted on 11/1/09 at 09:27 AM |
focus
idle speed control valve could cause it as could an air leak,check the pipes coming off the inlet manifold,especially the one going to the crankcase
breather they have a tendancy to suck in and split.only other thing i can think of as you have no diagnostic eq to aid you is the throttle postion
sensor or its voltage out of range.try loosening it push the throttle a few times and do it back up.something to start you off............
YQUSTA
| posted on 11/1/09 at 09:38 AM |
Cheers jonesier will give it a go
YQUSTA
focijohn
| posted on 11/1/09 at 09:42 AM |
mine was the same idle control valve was FUBARD. Mine's a 2000 1.8!
Anyone going slower than you is an idiot. Anyone going faster than you is a maniac.
Too many targets but too few bullets.
the_fbi
| posted on 11/1/09 at 10:57 AM |
Worth checking all the plug leads are seated OK.
As mentioned by jonesier1, there's a rubber hose from the rear of the inlet manifold (quite a long way down) which is known to go soft/gooey,
split and basically is a pile of poo.
This joins up with a metal pipe which goes under the thermostat housing then to the ccv/oil separator on the front of the block.
The whole lot of that, including the 1 way valve (the bit which pushes into the top of the oil separator), is worth replacing. Under £20 for all the
parts and needs doing if it hasn't been since new.
