Author: Subject: Sealing chipbaord adges.
bigandy
posted on 15/2/09 at 06:05 PM Reply With Quote
Afternoon all,
I've just built a few shelves and a new workbench in the garage, and I have used up some 18mm chipboard I had going spare. Having cut everything out and sanded the sharp edges, the chipboard is very crumbly around the cut edges.
Does anyone have any bright ideas for something that can be painted on it to stop the edges crumbling/giving splinters? I was thinking some kind of glue or sealant might do the trick?
I'm beginning to think it would have been easier to just go and buy some 18mm marine ply instead
Dammit! Too many decisions....
mr henderson
posted on 15/2/09 at 06:18 PM Reply With Quote
Get some car body filler. Work it in well, then sand it smooth when it has set. You may need to do it a couple or three times.
Ply would be easier but still not perfect, due ti the amount of endgrain, there are also voids where there are empty knots in the intermediate layers.
MDF would be easier still, but requires several coats to get reasonably smooth.
I know lots about painting sheet materials
John
Canada EH!
posted on 15/2/09 at 06:28 PM Reply With Quote
Try you local builders supply for aluminum edging, looks like angle iron, or wood byproduct edging material, glues on with contact cement.
LBMEFM
Purchase a thin prepared timber baton 18mm wide, pin and glue to the edge, when set sand down and there you have one perfect edge ready for primer and painting. No mess, quick and permanant.
Personally- didn't bother. No problems yet four years on.....
jacko
posted on 15/2/09 at 06:32 PM Reply With Quote
I have 20mm chipboard shelves in my garage and i bent some 14g alloy in to channels and put that on the edges it also makes the shelves stronger
l0rd
posted on 15/2/09 at 06:53 PM Reply With Quote
Duck tape?
designer
posted on 15/2/09 at 07:14 PM Reply With Quote
A few coats of varnish will do it.
Phil.J
Use chipboard iron-on edging, only takes a few minutes.
roadrunner
posted on 15/2/09 at 07:43 PM Reply With Quote
At last ,someone with the correct answer.
mr henderson
posted on 15/2/09 at 08:01 PM Reply With Quote
You need a very clean cut edge to get a good result this way, and a trip to the diy shop. My answer was fine, and could be carried out with materials found in most garage workshops.
jacko
posted on 15/2/09 at 08:34 PM Reply With Quote
A chippie would say that
mookaloid
posted on 15/2/09 at 10:10 PM Reply With Quote
Originally posted by l0rd
Duck tape?
I like this solution - it's only a shelf in a garage after all.
DarrenW
posted on 16/2/09 at 02:00 PM Reply With Quote
For garage shelves either nothing and replace if / when required. If you have to seal PVA glu or dregs from end of a silicon tube will do the job. However the rest of the surface will absorb moisture over time and knacker them anyway if you are concerned about dampness (ie in unheated detached garage).
I wouldnt waste valuable duck tape etc on garage shelves.
