Author: Subject: PINTO Temp Sensor Thread
omega0684
posted on 22/2/09 at 06:25 PM Reply With Quote
does anyone know what the thread is on a standard pinto water temp sensor, i can't find my thread measurers.
reason being i have a racetech temperature gauge and the std pinto sensor makes the gauge read higher than what the water temp actually is, so i need to get the racetech sensor and need to know which thread size to get
[Edited on 22/2/09 by omega0684]
flak monkey
posted on 22/2/09 at 06:36 PM Reply With Quote
1/8" NPT
Sera
http://www.motosera.com
omega0684
posted on 22/2/09 at 07:16 PM Reply With Quote
cheers fella, looking at the sensors none of them are 1/8, there is a 5/8 but that will obviously be too big, is there anywhere else in the block you can take the temperature from? (other wholes etc)
sensors here
flak monkey
posted on 22/2/09 at 07:24 PM Reply With Quote
If your inlet manifold has it, you can put a temp sensor inbetween cylinders 2 and 3. Thread is 1/4"npt.
Otherwise you'll need to fit it in the top hose to the rad in an adaptor.
Sera
omega0684
posted on 22/2/09 at 07:33 PM Reply With Quote
ive got the pipe between 2 & 3 but my MS temp sensor is in there.
