Author: Subject: How long does an egg last?
Mr Whippy
posted on 4/3/09 at 01:43 PM Reply With Quote
Yesterday missy’s cursed corsa lost all its water due to the water pump gasket bursting, literally was pouring out the damn thing all over the road, so I popped in an egg (just the white bit) and as usual leaks fixed. But I was wondering how long does this tend to last? Fixed a burst casting on the JCB a year ago this way and it’s still fine. Just can't be arsed taking the pump of this car as it’s a large diesel stuffed in there with no room to work
any idea?
Triton
posted on 4/3/09 at 01:47 PM Reply With Quote
I thought that was an old wives tale?....you are now saying it eggsactly works?....
www.tritonraceseats.com
www.hairyhedgehog.com
Mr Whippy
posted on 4/3/09 at 01:48 PM Reply With Quote
works great, once the waters hot, the leak stops instantly. Mustard does the same but I can't stand that stuff
ReMan
posted on 4/3/09 at 01:58 PM Reply With Quote
Probably not quite as long as it lasts in a tyre. But at least till you sell it?
[Edited on 4/3/09 by ReMan]
Daddylonglegs
posted on 4/3/09 at 02:13 PM Reply With Quote
Yup it defo works.
My old dear used one years ago and it stayed leak-free for over a year!!
martin1973
posted on 4/3/09 at 03:19 PM Reply With Quote
no antifreeze then?
normally antifreeze kills the egg,
martin
Mr Whippy
posted on 4/3/09 at 03:29 PM Reply With Quote
Originally posted by martin1973
no antifreeze then?
Well not sure about that, the digger runs 100% antifreeze and so far the egg has sealed successfully a 1 inch long crack in the thermostat casting, missy’s car has got antifreeze in it too
posted on 4/3/09 at 03:31 PM Reply With Quote
Apparantly ground pepper works well too....
Too often these fixes work too well.... I once cycled 20 miles to see some R/C aeroplanes only to find that my thieving flat mate had half-inched my puncture repair kit. In the end I used some superglue and a little bit of wing rubber-band and it worked nicely for six months
Result!!!
speedyxjs
posted on 4/3/09 at 08:01 PM Reply With Quote
Iv seen the egg trick used plenty of times. Its amazing these companys that sell products to fix leaks actually make any money
craig1410
posted on 5/3/09 at 12:08 AM Reply With Quote
You can egg-spect it to last just as long as the first time you REALLY need the car and then it will egg-splode.
Sorry... only yoking
dogwood
posted on 5/3/09 at 09:37 AM Reply With Quote
Doh..
I hate "egg" jokes.
I find them Eggsasperating......
FREE THE ROADSTER ONE…!!
