Author: Subject: Spray foam roof insulation for garage?
gregf27
posted on 13/3/09 at 09:05 PM Reply With Quote
I am thinking about getting the pitched slate roof of my garages sprayed with the Polyurethane spray foam stuff to get it insulated properly, as it aint warm and I dont fancy any bits of tiles dropping onto my kitcar!!
has anyone on here had there roof's done, any pros and cons? any firms they can reccommend in the west Mids area, and what sort of price would it be??
Greg
daniel mason
posted on 13/3/09 at 09:10 PM Reply With Quote
could you not use kingspan insulation between the rafters? its high density with good insulation values, and you cut it with a saw and could therefore do it yourself.
Guinness
posted on 13/3/09 at 09:15 PM Reply With Quote
You could give my mate John a ring.
He's local to me, but has been in the trade for years. He might travel.
Bellyou Trading
Durkin House
Seghill Industrial Estate
Cramlington
Northumberland NE23 7DR
Telephone:
0191 2374158
Fax:
0191 2373730
Mike
SteveWalker
posted on 13/3/09 at 09:24 PM Reply With Quote
There have been reports (Watchdog IIRC) suggesting that sprayed on foam can sometimes push tiles out of place and damage the roof. The foam then makes repair very difficult.
SteveW
jlparsons
posted on 14/3/09 at 09:55 AM Reply With Quote
Second that. PITA to replace tiles or work on the roof after.
Probably the best insulation there is though - no gaps whatsoever! Also as it's closed cell I think it's very unlikely to encourage timber rot like other insulations can sometimes.
NS Dev
posted on 14/3/09 at 06:22 PM Reply With Quote
Great stuff.
Though it can shuffle the tiles/slates a touch, it is also waterproof and glues them on! Wouldn't like to then have to replace one but you shouldn't have to.
You can get diy kits, will post info if I can find it.
NS Dev
posted on 14/3/09 at 06:30 PM Reply With Quote
loads on google but here's the one I was looking at for my house roof:
http://www.spray-insulation.co.uk/loft_insulation.htm
gregf27
posted on 14/3/09 at 10:39 PM Reply With Quote
Cheers for the replies all,
will try and get a few quotes done,
