Author: Subject: Exhaust pipe
speedyxjs
posted on 19/3/09 at 07:05 AM Reply With Quote
Exhaust pipe
Where can i find a straight section of exhaust? Ideally i need about 2 metres of it. Cant find much on ebay.
DanP
posted on 19/3/09 at 07:15 AM Reply With Quote
milner offroad are very reasonably priced for SS pipe.
Dan
speedyxjs
posted on 19/3/09 at 07:20 AM Reply With Quote
Is stainless the same to weld as mild steel?
Macbeast
posted on 19/3/09 at 07:24 AM Reply With Quote
If it's MIG, I think you need expensive stainless wire
Benzine
posted on 19/3/09 at 07:47 AM Reply With Quote
I've got a couple of meters of straight 2" stainless pipe if you're interested
bilbo
posted on 19/3/09 at 09:32 AM Reply With Quote
You can weld SS with normal mild steel wire and gas and it will work fine - but the weld will go rusty over time.
Using the Stainless wire will of course solve this (I think you need 100% argon gas as well?), but I understand, although I've never tried, that it's more tricky to get a good weld than with mild steel wire?
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
iank
posted on 19/3/09 at 09:59 AM Reply With Quote
Could get it from Merlin (they do both mild and stainless)
http://www.merlinmotorsport.co.uk/EXHAUSTS-Jetex-Exhaust-Parts/c223_224/index.html
But as a first try I'd wander along to an exhaust fitter at a quiet time and see if you can buy a section for beer money. Small independent might give better luck than a big chain.
Anonymous
speedyxjs
posted on 19/3/09 at 10:31 AM Reply With Quote
U2U sent Benzine
wicket
posted on 19/3/09 at 02:19 PM Reply With Quote
Got mine from here, not that far from you in Lancing
http://www.pipecraft.co.uk/
[Edited on 19/3/09 by wicket]
Danozeman
posted on 19/3/09 at 05:31 PM Reply With Quote
I do that. Theyl usually give u it for a drink.
Motor factors will do you a length of mild pipe. Mines does it for about 12 quid for 2 metres.
Dan
