Author: Subject: Help with Wheel identification
richard
posted on 13/4/09 at 06:29 PM Reply With Quote
I am trying to find out what wheels are fitted to the caravan i am trying to make into a car trailer so i can get some spares.
I though it was ford four stud but proved to be a bit narrower than the sierra wheels i have.
I measured the distance form one nut to the next and is 70mm and across the diameter is 99mm.
Can anyone help or point me to a place that will have this information.
Richard.
jacko
posted on 13/4/09 at 06:38 PM Reply With Quote
I think mini metro wheels fit
but check before buying
will121
posted on 13/4/09 at 06:41 PM Reply With Quote
try here
pcd chart
[Edited on 13/4/09 by will121]
Mark G
posted on 13/4/09 at 06:45 PM Reply With Quote
probably a 100 pcd.
There are many that will fit that. Ford are 108 iirc.
britishtrident
posted on 13/4/09 at 06:51 PM Reply With Quote
You need to measure the PCD (distance diagonally accross the stud centres) and stud diameter, if the chassis is old (you shold be able to deduce the year from the prefix on the chasss number plate).
But from you description most likely PDC is 3.75" with 3/8" UNF studs This PCD was use on the Maria/Ital and many small Triumphs.
[/I]
richard
posted on 13/4/09 at 09:36 PM Reply With Quote
Once again you guys turned up trumps.
I have acces to mates who have a few of those to try out.
Cheers again.
