Miks15
| posted on 20/4/09 at 01:33 PM |
brake problem (tintop)
Having some problems with the rear brakes on my dads honda accord. The Rear N/S brake pads have worn down stupidly quickly ( less than a month since
they were changed and one of thems about a mm off the metal and the other is about 3 mm.) Where as the O/S look as new in terms of depth.
What do we reckon the problem is and whats the best way to solve it?
Mikkel
| posted on 20/4/09 at 01:35 PM |
Seized caliper would be the first look see for me.
iank
| posted on 20/4/09 at 01:38 PM |
Check the handbrake is releasing on the worn side.
Anonymous
Miks15
| posted on 20/4/09 at 01:41 PM |
Handbrake is a drum style inside the disc so nothing to do with the caliper.
My first instinct was also a binding caliper. What do i need to do to fix it?
Mr Whippy
| posted on 20/4/09 at 02:11 PM |
whats the condition of the drum inner surface, if its too ruff is will 'sand' down the shoe
Miks15
| posted on 20/4/09 at 02:26 PM |
Its not in the drum thats the problem its the caliper that seems to be binding. causing the pads to wear down. The handbrake shoes are fine
britishtrident
| posted on 20/4/09 at 03:46 PM |
Unless the cable is binding the caliper is knackered ie needs new seals the inner fluid seals act as return springs with age or if the get
contaminated by oil they turn brick hard. -- don't be tempted to try free it off WD40 or similar will make it worse
[Edited on 20/4/09 by britishtrident]
[/I]
