chrsgrain
| posted on 9/5/09 at 02:20 PM |
Laser / water cutting stainless and CAD help
Hi all,
Its my Dads birthday soon, and he has had an idea for a garden sculpture consisting of 8 stainless 'legs' holding up a stainless ball
(don't ask me why as I've no idea!!).
I'd like to turn his concept into reality, and the best way would be to get the stainless 'legs' water or laser cut - is there a
SIMPLE CAD programme that I can download which I can then use to design the legs, and then give to someone to cut???
Any help gratefully received!
Many thanks
Chris
Miks15
| posted on 9/5/09 at 02:29 PM |
dont know about the program but if your looking for someone to cut it id recomened ANDYW7DE on here, did a few bits for me, he did the drawings in CAD
for me aswell from some dimensioned drawings i made
flak monkey
| posted on 9/5/09 at 02:30 PM |
I should think someone will have a copy of autocad lite you could have. There are a few free ones which will let you create DXF files too, but none
spring to mind.
Sera
http://www.motosera.com
g.gilo
| posted on 9/5/09 at 03:00 PM |
cad
hi there
download "proge cad" free good and autocad compatable.
GRAHAM
iank
| posted on 9/5/09 at 03:06 PM |
It will be cheaper if all the legs are the same and 'nest' in a nice tessellated pattern.
I use QCad from Ribbonsoft for 2d which produces dxf files, and I found easy to use (much easier to get started than autocad)
http://www.ribbonsoft.com/qcad.html
Anonymous
the_fbi
| posted on 9/5/09 at 03:21 PM |
I use emachineshop, which is a free download from http://www.emachineshop.com
You can even order your parts directly from the application too (which only really makes sence if you are in the US) but the pricing feature is good
so you can compare different designs, materials, machines etc and the costs.
It'll export in dxf and I've used this a few times to get a local company with a laser cutter to knock out stuff for me.
It also will render you a nice "picture" of your design too, taking into account any bends you've placed which is great to visualise
a final design before getting it made.
