Author: Subject: Bargain spacers?
speedyxjs
posted on 18/5/09 at 06:20 AM Reply With Quote
Bargain spacers?
Wasnt too sure where to put this.
Has anyone used a 1 or 2p piece as a spacer or even maybe a washer?
Just thinking locost and all that
ReMan
posted on 18/5/09 at 06:38 AM Reply With Quote
Locost but illegal
speedyxjs
posted on 18/5/09 at 06:48 AM Reply With Quote
Ah well, worth a try
907
posted on 18/5/09 at 06:50 AM Reply With Quote
I bought some penny washers once...
The bloke charged me over 6p each for them.
Mind you, that's not as bad as my 2lb hammer... that was 15 quid.
That's inflation for you.
Paul G
AndyGT
posted on 18/5/09 at 07:16 AM Reply With Quote
yes, "defacing the queens head" is the official title.
Back to the days of decimalisation or just before when a small value coin of copper was more valuable in weight than the face value. People were just melting down the copper or using them as washers. An instant way of making money apparently.
The royal mint soon realised their error and introduced this law...
But who's going to undo a nut and bolt to see if someone has used a penny etc? Plus the age old question of "who did it?".
iank
posted on 18/5/09 at 07:19 AM Reply With Quote
Originally posted by ReMan
Locost but illegal
No it's not, the law that made it illegal was repealed in 1981*.
Biggest problem is they aren't flat so they make cr*p spaces/washers.
* The original offence was under the Coinage Offences act 1936 (section 26)
The act was repealed in it's entirety by the Forgery and Counterfeiting Act of 1981
Anonymous
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 18/5/09 at 08:38 AM Reply With Quote
i have seen a picture of it, wasn't it someone on here, dont know where else i would have seen it, used a couple of 5ps somewhere on the end of throttle cable at the carb end?
Slater
posted on 18/5/09 at 08:41 AM Reply With Quote
I used some 5p coins for my throttle return spring. They work just fine.
[img][/img]
tegwin
posted on 18/5/09 at 09:31 AM Reply With Quote
I find coins make perfect packers/spacers for using with pulling tools etc.....
I also have 4 1pc pieces in my carbs to replace the wax stats origionally fitted.... as said.. cheaper than buying real "spacers"... But I wouldnt want to use them as washers etc...the material integrity is debatable!
www.verticalhorizonsmedia.tv
MikeR
posted on 18/5/09 at 11:32 AM Reply With Quote
does that mean you're car is worth more now?
tegwin
posted on 18/5/09 at 12:01 PM Reply With Quote
No... but with the queen overseeing the mixture control on the carbs.... it sure does run nice!
Vindi_andy
posted on 18/5/09 at 12:14 PM Reply With Quote
When I was an Apprentice an apprentice master sent one of the apprentices for some food with a £2 coin.
The bill came to £1.93 so the apprentice being a bit of a joker drilled out the centre of the 2p coin and pressed the 5p coin into it.
When he gave it back he said it was a 7 pence coin
