steve m
| posted on 15/8/09 at 07:37 AM |
Push bike slow puncture. can i use a car tin foam filler ?
I am not sure what they are called but the "spare wheel in a can" type of thing
Daughters bike has two slow puncture's so i thought of using and old can that was knocking about (literally !!) in the boot
can i ??
regards
steve
[Edited on 15/8/09 by steve m]
bilbo
| posted on 15/8/09 at 07:41 AM |
The stuff's called 'tyreweld', but I'm not sure if you can use it on bicycles though?
Ah, wait. They do a special version here:
linky
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
StevieB
| posted on 15/8/09 at 07:42 AM |
Probably just as cheap to buy a new inner tube.
Inner tube repair kits are even cheaper though, and really easy to use.
steve m
| posted on 15/8/09 at 07:50 AM |
I am not funding her inner tubesm as she owes me £££ anyway, i was just thinking of an easy fix
plus she is 27 !!
adithorp
| posted on 15/8/09 at 07:51 AM |
Just fix them. Easiest is to stick new tubes in especially if they're old/cheap tubes that are in.
If you can't manage that how are you building a car?
adrian
http://jpsc.org.uk/forum/
steve m
| posted on 15/8/09 at 08:01 AM |
"If you can't manage that how are you building a car? "
<<<< on the road in 1999 ??
10 years on the road, in fact so long ago i cant remember how to build !
and as i said, daughter owes me 1000's so im not funding two inner tubes, but i dont mind fitting them
AND DAUGHTER IS 27, if it had been for my Grandson, i wouldnt have even thought about any cost
| posted on 15/8/09 at 09:20 AM |
check the tyre for alien objects, usually easier by running your finges over the inside of the tyre.
beware you don't cut yourself.
adithorp
| posted on 15/8/09 at 09:55 AM |
Sorry mate. Didn't have all the facts when I started typing but understand now!
adrian
Ninehigh
| posted on 15/8/09 at 10:54 AM |
Milk, unscrew the valve and pour some milk in then get her to keep spinning them for an hour or so while it turns into cheese. Would be better to do
on a sunny day though.
How's that for locost? 28p for a pint isn't it?
D Beddows
| posted on 15/8/09 at 11:04 AM |
Surely if no one can be bothered to pay a whole £2ish for a puncture repair kit you may as well just stick it in and if it doesn't work you can
argue about why no one could be bothered to spend £2 to do it properly afterwards!
bob
| posted on 15/8/09 at 01:15 PM |
Steve you are one tight git
Tesco value puncture repair kit £1 last time i purchased one.
Actually quick edit to say i am sure i have seen the value repair kits for 50p
[Edited on 15/8/09 by bob]
Ninehigh
| posted on 15/8/09 at 01:27 PM |
Yeah but then she'll owe him £1000.50
RK
| posted on 15/8/09 at 03:02 PM |
I am fairly certain that she can sue you for all you've got if you don't repair this adequately for her. I suggest a new tube. This is the
easiest solution if you won't do the find-the hole-provided-it's-the-only-one, patch/glue procedure.
| posted on 15/8/09 at 08:03 PM |
Tell her to get a puncture repair kit and you will show her how to do it.
gazza285
| posted on 15/8/09 at 08:42 PM |
Buy her a car you cheap git!
Staple balls
| posted on 16/8/09 at 01:24 AM |
Be *very* careful depending on your area, on a few occasions I've found broken off hypodermic needles in bike tyres.
steve m
| posted on 16/8/09 at 07:56 AM |
Problem solved, daughter has her bike back with two flat tyres,
and wife has a nice gleeming new bike
Wife happy
Daughter not
perhaps she will get the message ???
