john77cars
| posted on 22/8/09 at 08:11 PM |
onboard bullet cams
im after buying a on board camera kit to fit onto my rollbar,anyone know were i can get one from and which ones are good,i dont want to spend silly
money though.
brianthemagical
| posted on 22/8/09 at 08:58 PM |
ORPONLINE
Top quality equiptment, with good, helpful, knowledgeable staff.
mark chandler
| posted on 22/8/09 at 09:31 PM |
Do not get a CMOS camera, these are only suited to CCTV, you need to spend here.
I searched for an MP4 player that included AV in, a ministry of sound one fitted the bill, picture is okay on PC but rubbish on big television. This
is the limitation of the recorder.
Get a good camera in the first instance is my advice, spend more on the recorder at a later stage.
Alternative is get the best standard digital camera and just strap this to the roll cage, a bit ugly but just as effective.
brianthemagical
| posted on 22/8/09 at 10:08 PM |
CCD's are so cheap nowadays it's unlikely you'll be looking at CMOS chips. The advantage of CMOS, and where they may be sutible for
your aplication is there lower power consumption.
Most similar cameras use very similar chips, giving similar picture quality.
For best value one of the all in one camera recorders is a good bet, it just depends on you budget.
[Edited on 22/8/09 by brianthemagical]
mr_pr
| posted on 22/8/09 at 10:38 PM |
Look at these guys. Got my bullet from them to use when skiing at first. They do all sorts of packages and I am using one of their ski packages. To
convert it to car use all I am going to do is get a variable gain mic, so you don't get that awful wind/mic distort that most people have.
Dog Cam Sport
My Build Progress
rb968
| posted on 22/8/09 at 11:20 PM |
I've used these lot for cctv for work and they are always very helpful
http://www.rfconcepts.co.uk/helmet_cameras.htm
Rich
Madinventions
| posted on 22/8/09 at 11:35 PM |
I use one of these - £21 from Hong Kong via eBay! You could mount it to your rollbar using jubilee clips, or to your bodywork using rubber suction
cups and P-clips like the DogCam system uses.
eBay link to the camera
eBay link to the rubber suction cups
Ed.
Madinventions
| posted on 22/8/09 at 11:39 PM |
Oh, and to get rid of the wind noise problem I've mounted a separate microphone just behind the windscreen. It's only a small condenser
type with a tiny amplifier to push the output up to line level and to smooth out the power supply, but it works like a charm!
Yes, I got it from eBay too.... (it is the best shop in the world after all!)
Ed.
clairetoo
| posted on 23/8/09 at 08:29 AM |
Ed.
Thats neat - but how do you record stuff from it ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
