Author: Subject: Buying Glass and etching
alistairolsen
posted on 19/1/11 at 08:07 AM Reply With Quote
Where can I buy a largish pane of glass? Probably 4 feet by 3 and around quarter of an inch thick? Also how much would something like that cost?
Second, say I wanted to etc a chessboard pattern onto it, how would I be best to do that?
Something like that
My Build Thread
Strontium Dog
posted on 19/1/11 at 08:23 AM Reply With Quote
I don't know where to buy glass in Glasgow but you will need to get toughened glass with ground edges or it could all end in tears. Or or a bloodbath!
Etching can be done with a sand blaster and masking off the bits you want to leave clear. Google for the best medium for the finish you want. Practise on some scrap first so you get the hang of it or you might end up with stripy, uneven etch.
swanny
posted on 19/1/11 at 08:38 AM Reply With Quote
when we've done it in the past we have used the sand technique, however for a small amount there are chemical etchs that you can use, think it coems in a can. not sure if the chemical route would give you a finer finish.
MikeRJ
posted on 19/1/11 at 09:22 AM Reply With Quote
This stuff
trextr7monkey
posted on 19/1/11 at 09:28 AM Reply With Quote
We buy glass for coffee table tops etc that the kids make from local glaziers-same guys that do the shop windows etc once cut to size and edges polished it gets sent away to be toughened, takes a couple of weeks all in.
You could use etched glas vinyl on the underside of the glass which is a good substitute for etching, depending on size we could prob cut you the squares.
atb
Mike
alistairolsen
posted on 19/1/11 at 11:00 AM Reply With Quote
atb
Mike
Any idea on a ballpark cost Mike?
Ill be in touch about the film, it was my intention to do it on the underside anyway!
My Build Thread
