Simon
| posted on 25/11/12 at 05:32 PM |
Repointing q
Folks,
About to do some repointing on dry internal garage wall prior to plasterboarding and just need a bit of advice re mortar.
Should it be dryish, wetting or middlish and should I wet the brickwork or not.
Cheers very much
Simon
zilspeed
| posted on 25/11/12 at 06:27 PM |
The important thing about the water content is to be sufficient to hydrate the cement.
You also want it to be workable so a bit of plasticiser wouldn't hurt things to make it a bit easier.
It wants to be stiff enought that if you trowel it into a shape, it will pretty much stay there. this should help you get your water quantity
right.
Really, just like a rudimentaru slump test as applied to concrete.
Hydration is the mechanism that actually causes cement to become the finished article. It's not at all about drying out, so a semi dry mix
really isn't much use.
austin man
| posted on 25/11/12 at 06:52 PM |
few drops of wshing up liquid wont go amiss
Simon
| posted on 25/11/12 at 07:14 PM |
Excellent, a concrete Aero
Simon
| posted on 25/11/12 at 08:01 PM |
If it's dry and internal and you are covering it with plasterboard why bother pointing it ? If you are sticking the boards up with drywall
adhesive you don't need them too smooth anyway.
cliftyhanger
| posted on 26/11/12 at 10:23 AM |
I really would dot and dab onto a garage wall. That stuff pulls all the moisture out of waht it is on and leaves lovely damp patches everywhere. Had
this on a victorian house (solid walls, which appeared dry). Had to take it down and batten and board with a vapour barrier, MUCH better solution.
Simon
| posted on 26/11/12 at 11:39 AM |
The outside wall has had the extension built on top of it, and you can see daylight through some if the old single skin
Simon
