Author: Subject: Nexus 7 Wifi fix
JeffHs
posted on 20/2/13 at 09:51 AM Reply With Quote
Nexus 7 Wifi fix
Just in case anyone on here is going mad trying to fix poor wifi on a Nexus7.
Mine has worked perfectly for 3 months and then recently the signal has been appalling unless it's right on top of the router.
Forums suggest operating system upgrade is the problem but nothing I tried worked. Then I discovered a post that said the problem may be caused by the back of the case being loose. Sure enough in the top left corner there was a gap. I snapped the case back in place and instantly it's fixed. Seems that's where the antenna is.
snakebelly
posted on 20/2/13 at 11:06 AM Reply With Quote
Wish the fix for iPhone 5 wifi issues was that easy, had to drive and hour and a half each way to my "nearest" apple store to get mine swapped:-(
