Greenie
| posted on 29/4/13 at 10:12 AM |
Router configuration
My network provider is Talk Talk which I am using a Netgear hub for connection, although I believe this may be faulty, I still have, from a previous
provider, a BT Home Hub, my question is can I configure the BT hub to accept my Talk Talk connection and if so can anyone help by explaining how this
is done?
cheers in anticipation Peter
cerbera
| posted on 29/4/13 at 10:42 AM |
Yes you can.
You need to log into your home hub (192.168.1.254 I believe) from a browser window then find and change the internet username and password to your
Talk Talk one.
HTH
[Edited on 29/4/13 by cerbera]
Greenie
| posted on 29/4/13 at 10:46 AM |
That sounds easy enough but how do I find the user name fr my Talk Talk one, I have the pass word..... Sorry to sound thick, I am better off with a
spanner in my hand not a PC....
Regards Peter
cerbera
| posted on 29/4/13 at 11:00 AM |
It should be with the bumf they sent you. It will be yourlandline@talktalk.net
You will also need a username and password to log onto your home hub. I think the username will be admin and the password should be on label on the
hub itself.
HTH
EX01
| posted on 29/4/13 at 11:12 AM |
It used to be that the BT Home Hubs were locked to BT only Broadband, I know because the only way I could get the spare one to work for my dad when
his router died was to flash the BT router with a custom ROM to unlock it.
So if you cant get it too work, I would Google the BT router model (normally printer some place on it) along with "Can I use it on another
provider"
I know BT after a certain modle number also prevented flashing a custom ROM so you may be out of luck...... Good Ol BT.
The beauty of a build is not the build or the drive when it’s done, it’s the sneaking the funds slowly past the wife as she remains blissfully
unaware!
cerbera
| posted on 29/4/13 at 11:17 AM |
I didn't realise that was the case.
britishtrident
| posted on 29/4/13 at 02:18 PM |
it would probably be easier to pick-up a secondhand ADSL router off ebay for buttons. A quick ebay trwal brought up some actual Talk-Talk
D-Link routers
[/I]
Not Anumber
| posted on 29/4/13 at 05:08 PM |
ADSL routers are relatively cheap and easy to pick up. I'd just buy one if there is a risk that your BT Home Hub router cannot be reconfigured.
Greenie
| posted on 29/4/13 at 07:51 PM |
Cheers to everyone for there valuable advise.....struggling with the BT one may just take the ebay route.
Cheers again Peter
