steve m
| posted on 6/8/13 at 02:01 PM |
12"x12" stainless steel square wanted ?
Hi Guys
300mm /12" x 300mm/ 12" x 2mm-4mm thick, stainless steel square wanted ?
must be flat and blemish free, but could be brushed finish
does anyone know of a supplier or any one able to cut such any item ?
regards
benchmark51
| posted on 6/8/13 at 03:00 PM |
I don't what you want this for, but is it for stone guards?
If so, I bought some that are 29mm x 29mm and cut diagonally at the bottom(usual stone guard shape)
mirror finish 1 side
They are currently £7.50 inc each at kitspares
http://www.kitspares.co.uk/shop/item.php?cat=2&product=4727&catsub=7
steve m
| posted on 6/8/13 at 03:34 PM |
Stone guards !!
NO, its for me to make a kitchen clock, that is why its 300mm x 300 mm as to fit in a perfect place
Plan is to drill a hole in the middle, and mount a clock mechanism in the hole, and stencil a black cross for 12-6 and 9-3
liam.mccaffrey
| posted on 6/8/13 at 04:03 PM |
I'd almost guarantee you could get that as an offcut on ebay.
Build Blog
Build Photo Album
steve m
| posted on 6/8/13 at 05:29 PM |
Thanks Liam,
Ive tried ebay, but not much luck yet
iank
| posted on 6/8/13 at 05:52 PM |
907 might know a supplier who would do an off-cut.
Anonymous
NigeEss
| posted on 6/8/13 at 09:03 PM |
2-4mm for a clock
mcerd1
| posted on 7/8/13 at 07:36 AM |
try these guys: http://www.nogginend.com/
although at 2 - 4mm think I'd think your more likely to get a raw bit of metal to polish/brush yourself...
i've been getting on quite well with these things for all my little projects:
http://www.frost.co.uk/satinising-mops-6-inch-and-set.html
the fine one makes an nice job on alloy and the course one is quite good for steel, but its really a satin finish rather than a brushed finish
renetom
| posted on 7/8/13 at 04:41 PM |
Hi Steve
I have a piece of St steel sheet 300X250 polished one side & brushed the other
You are welcome to it if its any use
René
ashg
| posted on 7/8/13 at 05:07 PM |
have you tried
crawley metal services
elliot metals
colbridge Engineering
they are all local to you.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
steve m
| posted on 7/8/13 at 06:03 PM |
Thanks Guys
Wifey has changed her mind AGAIN,
But Rene's piece could be what im after, and im passing yours tomorrow, as off to collect the caravan!
MikeRJ
| posted on 8/8/13 at 02:49 PM |
Quick calc shows that a 12"x12"x4mm lump of stainless will weigh about 3KG! You might want to get a rawl bolt so you can hang the clock
safely
Could you perhaps laminate a thin sheet of stainless onto a some alloy plate (using e.g contact adhesive)? Would probably be cheaper as well as
lighter.
mcerd1
| posted on 8/8/13 at 03:42 PM |
safely
lighter.
I'd agree with your maths
304 stainless is about 7900 kg/m³, 0.3048*0.3048*0.004*7900 = 2.936kg
but I think you'd be best laminating a thin sheet (say 0.5mm) onto a block of MDF
if you don't want to see the edges of the wood you could get a slightly bigger sheet of steel and fold the edges over - this way you get brushed
steel edges that you wouldn't get with a solid plate
I got a 600x900mm sheet of 0.9mm brushed stainless of ebay for £25 delivered, thats almost enough for 6 clocks
Krismc
| posted on 11/8/13 at 04:38 PM |
I can get you stainless steel delivered to ya door cut and finished in any pattern. Ill get a price in brushed for you but id estimate £15-20.
kris
