| posted on 15/11/14 at 05:26 PM |
immersion heater 36
Is the length if immersion heater listed as per height of tank, so in reality they are shorter?
I measured tank to be 36 in high.
Heater i am looking at, one wire from the thermostat to heater element looks burnt plus coppet connector looks corroded, when powered the 13 a fuse
blows.
Does it sound like it is fixable?
robinsoncrusoe55
| posted on 15/11/14 at 05:43 PM |
immersion heater 36
Sounds like the heater is "down to earth......not repairable.
not sure, about the element length, think you're right,
36"element, for, a 36"tank
big-vee-twin
| posted on 15/11/14 at 05:53 PM |
Check heater with a meter for resistance to earth first, in my experience the thermostat burns out and causes the fault.
The stat just pulls out, easy fix.
http://www.triangleltd.com
| posted on 15/11/14 at 06:45 PM |
Thx for replies.
If it is thermostat, then since the heater and thermostat are one unit, the wholer lot needs replacing?
The brand is AEI, probably >20 yrs old.
Pricewise the thermst+htr is about five pounds more than just the thermostat.
.... one more q. I can see 27 and 36 in heaters both rated at 3 kw - any reason why the shorter 27 in cannot br used in a 36 in tank?
[Edited on 15/11/14 by 02GF74]
big-vee-twin
| posted on 15/11/14 at 07:32 PM |
thermostat is separate and just pulls out.
| posted on 15/11/14 at 07:49 PM |
Hmm googling indicates 27 in is correct size so a trip to wickes it is.... who sell the spanner at the lowest price.
TheGiantTribble
| posted on 15/11/14 at 09:53 PM |
Top entry immersion heater for a 36" cylinder is 27"
if you had side entry immersion heater, 11" or 14" immersion heater would be required
rash12
| posted on 15/11/14 at 11:05 PM |
yes as above top entry are 27 inch side entry are generally 11 inch on domestic systems
skodaman
| posted on 16/11/14 at 01:26 AM |
"Hmm googling indicates 27 in is correct size so a trip to wickes it is.... who sell the spanner at the lowest price."
The last immersion heater I took out refused to budge and the proper spanners just bent. In the end I had to take out the whole cylinder put the
heater nut in a mechanics vice and turn the cylinder to loosen the nut. Be careful doing this cos easy to bend the cylinder and they're
expensive to replace.
Skodaman
| posted on 16/11/14 at 04:17 PM |
..... wellas half expected the heater nut wont budge.
Taking the tank out in not convenient. Is it possible to drill into the brass nut and hacksaw it out.
