ruskino80
| posted on 20/5/15 at 09:09 PM |
residential electrical questions
hi, just doing a kitchen refurb for a customer and the electrician has blobbed on me.
the old oven was plugged in via a 13a plug
the new oven (2.4 kw so only 10 amps) requires min 3 core 1.5 mm flex h/r. question is can I simply install the new flex back into a 13amp plug?
on the existing wiring the socket beneath the countertop is controlled by a 13 amp switch fused spur fitted above the top which is spurred of the
dedicated kitchen ring.
second question is that I know installing the new oven is not notifiable based on not altering the supply but can I install it myself?
I am not an electrician, I am not part p registered but I do deem myself competent.
thanks for any help
rich
tegwin
| posted on 20/5/15 at 09:48 PM |
Theres a 13 A socket behind the oven isn't there? So you can quite easily plug in the new oven without doing any wiring can't you?
www.verticalhorizonsmedia.tv
daniel mason
| posted on 20/5/15 at 09:52 PM |
Youl still ned to terminate connections in the back of the oven!
| posted on 21/5/15 at 06:45 AM |
Most sub 13a ovens come with the flex fitted. I'd fit it without a second thought, it's not notifiable.
Slimy38
| posted on 21/5/15 at 07:28 AM |
We had the same with our cooker, although I changed the wall plate for an oven junction box (I don't know the proper term) so it was fully wired
in rather than just plugged in. Possibly a bit overkill but apart from anything the plate was more flush with the wall so the oven fitted better.
britishtrident
| posted on 21/5/15 at 12:08 PM |
Plug -- if you use the oven to any great extent at some point you will need to pull it out an fit a new heating element which only takes 5 minutes
if you can just pull it out and unplug it..
[/I]
britishtrident
| posted on 21/5/15 at 12:11 PM |
That was certainly the case with the Baumatic we fitted a couple of years back.
[/I]
