James
| posted on 30/4/20 at 04:57 PM |
Repairing fibreglass handle log splitting maul
Greetings all,
Hope you're all handling the lock down ok!
Quite a few years ago I bought the Roughneck log splitting set from Screwfix.
https://www.screwfix.com/p/roughneck-log-splitter-set-3-pieces/48279
They're not too bad once sharpened!
However, it hasn't long before the 6lb maul head came off the fibreglass handle. This MAY have been because I used the back (sledge hammer) end
a few times to smack the wood grenade into logs. Either way, the araldite holding the head to the handle has cracked.
Because I hate throwing stuff away I've found some threads elsewhere about repairing these with various 'slow cure' araldites.
However, it struck me the other day (ouch! ) I might be able to fit a wooden handle to the same head as easily.
Any thoughts on the best course? I have already bought the recommended araldite but I'm a bit worried about how I set the head
'straight' on the handle. Having said that fixing it 'straight' on a wooden handle might be harder still!
Cheers!
James
- Muhammad Ali
J666AYP
| posted on 1/5/20 at 12:47 AM |
Personally I would swap out the handle for a nice wooden one. Having the head held on with epoxy is a whoopsie waiting to happen.
J
roadrunner
| posted on 1/5/20 at 07:18 AM |
Can you not open the head of the axe so when you fit a proper wooden handle you can drive wedges into the end.
David Jenkins
| posted on 1/5/20 at 07:41 AM |
That is the traditional way to do this - you can buy wedges, although most people on this forum can probably make their own! A nice piece of ash
would do a very good job as a handle.
[Edited on 1/5/20 by David Jenkins]
AlexXtreme
| posted on 1/5/20 at 08:06 AM |
The handle is made from a thermoplastic so the epoxy Araldite will always crack up in the end.. though it might sound odd but lightly burning or
darkening the surface of the plastic with a flamecan create a better bond with the epoxy. I would say wedges in the plastic are likely not to work so
replace with a wood handle if you can. I have had an axe head come off when it was stuck in a log overhead.. luckily the momentum meant it landed
behind me!
MikeR
| posted on 1/5/20 at 07:13 PM |
I've got the same maul and have used the reverse to hit the grenade without a problem. I have bashed off the soft rubber just before the head.
Considering the force going through the head, I'm not sure if be happy with a bodged solution. Get an ash blank.
