Author: Subject: Polish scratches from Styrene window
number-1
posted on 5/7/23 at 05:46 PM Reply With Quote
Can anyone suggest a way to remove scratches from a summerhouse window?Its a Styrene window and was left for 3 years with the green film on both sides, which in the sun over 3 years went brittle and wouldn't peel off in 1 piece.
I took a blade to it but as the Styrene flexes its left scratches at each end of the blade on several places
Does anyone know if there's a way to polish them out?
N1
indykid
posted on 5/7/23 at 10:07 PM Reply With Quote
I'd replace the sheet. How big is it?
You might get away with brasso, it was what we used in school for acrylic projects, but it's always going to look a bit secondhand unless you can bring the surface around the scratch down to the same level as the root of the scratch.
number-1
posted on 6/7/23 at 02:43 PM Reply With Quote
Hi mate
Its around 1550mm x 620mm at a guess.
