graememk
| posted on 24/8/06 at 01:30 PM |
vectra probs
I have a 52 plate 3lt diesel vectra that I have had from new, at 6 months old it was on the rolling road where i had it set up for better bhp, and the
car has now done 60k, but it keeps blowing the turbo intercooler hose, as in ripping it apart not blowing it off its connections, you can still hear
the turbo start to boost around 2400 rpm and you can feel it pull so I don’t think there’s a prob there, it always lets me down as I accelerate, the
car is fitted with a dump valve ( none atmospheric so no boy racer whooshes) any ideas chaps before i have to get the £45 an hours guys to look at it
? I cant keep buying £30 hoses every month.
| posted on 24/8/06 at 01:46 PM |
to my untrained eye, its either too much boost, weak pipes or wrong fitting causing them to be stressed. We can probably rule out weak pipes since
you've had a few (i assume you used approved parts?). Fitting, you'd know if it was fitted wrong i guess.
So that leaves too much boost, possibly caused by a stuck wastegate? Have you fiddled with the boost control? Is it mechanical or electrical boost
control? Does it feel quicker than it did originally?
graememk
| posted on 24/8/06 at 01:55 PM |
genuine GM parts, according to the ecu its boosting at 8psi its alwas been the same from new looking back in the history.
car feels the same as always you feel the turbo cut in and out
chockymonster
| posted on 24/8/06 at 02:34 PM |
Replace it with a bit of samco?
graememk
| posted on 24/8/06 at 03:05 PM |
i was thinking about that but i think there maybe a prob somewhere didnt know if its a common prob
andybod
| posted on 24/8/06 at 04:55 PM |
just a thought but make sure you waste gate actuator isn't seized/not working correctly and when you off accelerate waste gate not opening
causing pressure build up
oooops just read post above sorry
[Edited on 24/8/06 by andybod]
