joneh
| posted on 7/9/06 at 08:37 AM |
Renault Clio 1.2 Stalling
Hi guys,
My missus has a '98 Renault Clio Biarritz and every so often it stalls and is a complete pig to get going again.
Any idea on the best thing to check for?
Cheers, Jon.
mike smith1
| posted on 7/9/06 at 08:51 AM |
friend had a similar problem with his clio, turned out to be coil pack
HTH Mike
fesycresy
| posted on 7/9/06 at 09:02 AM |
The only real answer is to plug it into a diagnostic machine and get the fault codes.
You don't necessarily need to go to the main dealer, but some garages diagnostics don't to pick up some codes.
ceebmoj
| posted on 7/9/06 at 10:03 AM |
hi,
im in stockport manchester if you can get hear I can read faults for you.
I have a multy tester pro
http://www.autodiagnos.com
ps that where I work
PPS
http://www.mongoliarearewethereyet.com
joneh
| posted on 7/9/06 at 09:47 PM |
Cheers guys. Will take it to my local garage - thanks for the offer not sure the car would make it to stockport manchester!
Thanks again, Jon
