Author: Subject: seat ibiza brakes
tom_loughlin
posted on 23/9/06 at 03:09 PM Reply With Quote
seat ibiza brakes
trying to fit some new pads to the front of my car and cant seem to get the caliper piston to retract.
any help would be brilliant.
i am guessig it is the same as a mk3 golf caliper?
its the 2.0l cupra model
froggy
posted on 23/9/06 at 03:53 PM Reply With Quote
what are you trying to push it back in with? g clamp or a proper tool works best and if you have abs then clamp the pipe and crack the bleed nipple to stop pushing fluid back the wrong way as some abs systems dont like this
posted on 23/9/06 at 04:54 PM Reply With Quote
I find a large pair of slip jaw grips works well , also known as water pump grips? Good for removing oil filters as well
Danozeman
posted on 23/9/06 at 05:39 PM Reply With Quote
Thats what i use.
As said above. Clamp the hose and slacken the bleed nipple, when u squeeze it back. U might wanna put a pipe on the nipple or itl make a mess.
Dan
darrens
posted on 23/9/06 at 07:03 PM Reply With Quote
some pistons you have to actually screw clockwise when pushing them back, Renault and the like are like this.
posted on 23/9/06 at 07:24 PM Reply With Quote
The only time I have come across wind back type pistons on front brakes is when the parking brake operates on the front wheels ie Citroen and some Saabs
SALAD
posted on 23/9/06 at 08:10 PM Reply With Quote
Did my Golf disks and pads all round the other day, ditto on the slip jaw grips. The backs need to be wound if you end up doing them.
