Brook_lands
| posted on 8/11/06 at 09:29 PM |
Any washing machine engineers?
Hoover AAA160 washing m/c switches on, welcome message appears on screen, 6kg load and Speed wash lights come on and then thats it. Wont do anything
else! What's the diagnosis?
I was fine with our previous washing machine. Electro-mechanical easy to fault find and in best Locost tradition I kept the thing going by building a
good one from two not so good ones. Then we got one of these wonderful computerised ones. I’m going to be sooooooooooo pi$$ed of if we cough
up £89 + vat or whatever the Hoover call out charge is theses days (never yet called an engineer out to any domestic appliance in 22 years so Ive no
idea) to have them perform some 2 min reset routine.
Thanks in advance
[Edited on 8/11/06 by Brook_lands]
ReMan
| posted on 8/11/06 at 10:04 PM |
Is there a drain filter on this, posssibly blocked with hairgrip or similar?
A common fault generally is that the machine thinks it still has water in so doesnt start filling.
Any other clues?
Brook_lands
| posted on 8/11/06 at 10:07 PM |
Thanks for the responce.
Worked fine the last time it was used. It doesnt get as far as registering or initiating any of the programmes. Checked the drain/filter, no problems
there.
ReMan
| posted on 8/11/06 at 10:10 PM |
have you tried giveing the door a bit of an extra push, in case its got a fancy double interlock, on you obviously posh(welcome message ) machine?
gary gsx
| posted on 8/11/06 at 10:14 PM |
We had a problem with our one checked the filter that was fine i then removed the rubber pipe to the drum that had a ball valve type of thing in it
and it was blocked by a sock, One of hers i might add
watsonpj
| posted on 8/11/06 at 11:21 PM |
try posting the problem here
mendit
hopefully you'll get a reply
good luck
Pete
chriscook
| posted on 9/11/06 at 07:15 PM |
I expect you want a washing machine repair man rather than an engineer. (sorry pet peev of mine)
