Author: Subject: intake temp
dilley
posted on 13/3/07 at 06:16 PM Reply With Quote
intake temp
Is there a gauge available to monitor intake temp??what about lambda??
Oh and while im posting, Im trying to find info on water/oil coolers if anyone has any experiance with these or has a link I'd be well pleased.
Thanks,Dilley.
locoR1
posted on 13/3/07 at 08:42 PM Reply With Quote
To keep it in the true spirit of locost I'm using this from Ebay just to monitor before and after temps from the chargecooler
Should give me a reasonable idea of what's happening temp wise!
http://cgi.ebay.co.uk/Compact-and-Tough-Handheld-Digital-Thermometer_W0QQitemZ280092326767QQihZ018QQcategoryZ50974QQcmdZViewItem
dilley
posted on 13/3/07 at 08:57 PM Reply With Quote
where do you put the sensos???
locoR1
posted on 13/3/07 at 09:28 PM Reply With Quote
I've put them both sides of the chargecooler in your case intercooler between the silicone hose and the alloy pipe with just the tip of the sensor pocking through a few mm then re tighten the hose clip carefully!
The sensors are a bit cheep and nasty but seem to work ok!
I haven't driven it with them fitted yet, still waiting for my wideband kit before I take it out again!
dilley
posted on 13/3/07 at 10:07 PM Reply With Quote
where did you get your charge cooler from, do you think they work better than an intercooler?? I have had to move my inntercooler under the bonnet as it restricted air flow really bad being in front of therad, Im just worried its not going to work properly, Im now trying to 'box in' the air flow to the rad and oil cooler,I have cut a hole in the bottom of the nose cone to give a direct flow to the oil cooler, everthing is fine im just trying to make sure that when the weather is really hot everything can cope!!whats your opinion on these matters, and what water/oil temp are you running under load??
Ive got to go to Northampton at some point,it would be nice to come and see you and have a nose and chat!!
Andrew.
[Edited on 13/3/07 by dilley]
posted on 14/3/07 at 09:25 AM Reply With Quote
take a look on www.thinkauto.com, look in the on-loine catalogue (.pdf) and in the oil cooler section - laminova or similar name.
dilley
posted on 14/3/07 at 07:55 PM Reply With Quote
bttt
