Surrey Dave
| posted on 14/6/07 at 07:10 PM |
Fitting Earth Clamps to 15mm Copper
Just going to fit some earth clamps (10mm cable) ,notice on a website that they advise using crimp connections on the cable and then screw to cable
clamps.
Is it OK to just strip the cable and wrap the cable round and clamp it?
ady8077
| posted on 14/6/07 at 07:29 PM |
Hi
Depending on the clamp you might find it too big to wrap around the screw, I open the strands to make a fork, and put 4 strands oneside the screw 3
the other
Adrian
| posted on 14/6/07 at 07:35 PM |
i fork it, 4 strands one side 3 the other, and nip tight.
Surrey Dave
| posted on 14/6/07 at 07:36 PM |
ok
So there is no requirement to have crimped connections?
It would pass an inspection?
rusty
| posted on 14/6/07 at 07:38 PM |
Cable can come lose it twisted and clamped. I would always use a crtmp of solder lug if possible.
no requirement that i know of. However, there are many in the regs - do you have a copy of the on site guide, assuming we're talking domestic
electrics?
ady8077
| posted on 14/6/07 at 07:42 PM |
Never had a problem in 21 years, but i dont work for an nic approved company
Adrian
Macbeast
| posted on 14/6/07 at 07:43 PM |
The ones I've used have a bar with a screw through it. You unloosen screw, push bared wire through either side and tighten up again so the bar
traps the wire. That's how they are designed.
ady8077
| posted on 14/6/07 at 07:53 PM |
If you havn't bought the clamps yet, how about these, no crimps required
http://www.hclfasteners.co.uk/index.php?node=0101
Adrian
caber
| posted on 14/6/07 at 08:17 PM |
Those look about as good as twisting the wire around the pipe and covering it with PVC!
Caber
Chippy
| posted on 14/6/07 at 11:18 PM |
I have used the easy bond clips, and they are very good, (IMHO), once clamped tight around the pipe you cant shift them. Remember to scrape any paint
from the pipe, (if its been painted). HTH Ray
steve matt
| posted on 15/6/07 at 06:56 AM |
Hi Dave no reg says you to have crimp but is better IMO, your local friendly sparks probably got a load in his van
