westf27
| posted on 1/8/07 at 08:01 PM |
attention all heating engineers
Got a combi boiler and having trouble with hot water to taps.If tap is open halfway i get constant hot water,if tap is fully open boiler starts and
stops giving intermittent hot and cold water.Was thinking divertor between the two heat exchangers,flow switch or could air in pump be problem ?
Should add central heating side is 100%
Hellfire
| posted on 1/8/07 at 08:39 PM |
Not a heating Engimineer mate but I had this problem with an old Vokera boiler I had. It turned out to be the inlet water pressure sensor... the
plunger in the valve kept sticking causing the problems you describe. As the boiler was so unreliable anyway I decided to bin it and get a better more
reliable one. I now have a Worcestershire/Bosch which is awesome in comparison.
westf27
| posted on 1/8/07 at 10:10 PM |
Thanks bud i will check it out
