trogdor
| posted on 28/1/08 at 12:33 PM |
what van
Hi all,
I have recently started working for my dad, he needed someone to help him run his business so i said i would help, i am starting to think it could be
a long term thing, it is worth while trying to make something of it.
anyways back to the point, the car i am using for the driving is my daily runner, a 106 with four gears, not the best combination for long distance
driving which i will have to do at some point, plus i will get taxed for using it as a business car which is not worth it.
Anyways what we are looking for is a suitable van, it needs to be cheap, something from the late 90's or earlier i would imagine, something that
is reliable, and that won't be expensive to insure for a 22 year old who has had his lience for 3 months!
any suggestions would be helpful
many thanks
mookaloid
| posted on 28/1/08 at 12:37 PM |
I would have thought it would depend mainly on what you need to carry....
trogdor
| posted on 28/1/08 at 12:39 PM |
fair point, it will be tools and laboratory equipment, i would proablly get a car van, but maybe a small van would be cheaper?
mcerd1
| posted on 28/1/08 at 01:00 PM |
whats does cheap mean to you - £500 or £2000 ?
when you say a 'car van' would a fiesta van (the ones with the normal car size back) or similar be too small ?
quote: Originally posted by trogdor
...the car i am using for the driving is my daily runner, a 106 with four gears, not the best combination for long distance driving
Snap
mines a 92' 954cc (1.0) 4 speed with a carb - it actually returns a good 50mpg if I take it easy on long trips (200+ miles @ ~60mph average) but
I only get 35mpg or less on the short 5 mile trips I do every day
I recently found out that 4 speed 106's have the same ratio in 4th as 5th in the 5 speed ones - but the 1.1+ cars get higher ratios
trogdor
| posted on 28/1/08 at 01:20 PM |
the budget would be £500 - £1000, a fiesta van would be ok but if its the same to buy and run a bigger van than we would go with one, astra van etc
my 106 is actually a 1.1 with SPI! couldn't believe that a car from 1994 could have four gears, can get 50mpg on mine if i take it easy i
didn't know that 4th is the same ratio as 5th. that would be a bonus as i was planning on changing the gearbox to a 5 speed when the clutch
needs sorting. if it is the same ratio there is no need to change, 4 speed is nice and simple!
[Edited on 28/1/08 by trogdor]
mcerd1
| posted on 28/1/08 at 05:47 PM |
couldn't believe that a car from 1994 could have four gears, can get 50mpg on mine if i take it easy i didn't know that 4th is the same
ratio as 5th. that would be a bonus as i was planning on changing the gearbox to a 5 speed when the clutch needs sorting. if it is the same ratio
Yeah, 5th gear was an option on base spec 1.0 and 1.1's up to the S2 in 96'
actually my prevoius car, a 1979 1.1 'L' Fiesta, has a sligtly higher spec than the 106 (apart from the radio)
Its certianly the case that the 1.0's got the same ratio's in 4 and 5 speed boxes most of the time - but you have to check really (give
the last 8 digits of your vin to your dealer and they can tell you the ratio's you've got)
As I understand it there is only 1 set of 4 speed ratios, but a few different final drive ratios (4.28 for most 1.0's and 4.06 for 1.1's I
think)
but the 5 speeds have a few more variations - depending on age, engine size and if its a 106, AX or Saxo.
If you want to up the ratio you could swap to a 5 speed from a bigger engined car - but you'd need to be careful about changes to things like
driveshafts/ hubs etc
4 speed to 5 is supposed to be a strait swap - but driveshafts could be different (mine has 3 stud wheels and these are slightly different at the
wheel end at least)
As you can probibly guess the problem is the made hundreds of slightly different versions
I've got a list of ratios I can send you if you like, but it only covers AX's and Saxo's
I found a 106 owners forum a couple of weeks ago: http://www.106owners.co.uk/forums/index.php
It was quite an easy job to swap the gearbox it doesn't weight much (well easy with a 4 post ramp, an engine beam and extra body to lift it
anyway)
I actually swapped mine a week ago to another 4 speed with the same ratios, when I thought it was the problem
-Robert
[Edited on 28/1/08 by mcerd1]
