Author: Subject: Relays
NigeEss
posted on 13/2/08 at 12:44 AM Reply With Quote
Relays
Are the numbers on the terminals a universal standard ? Need one like
the number 4 at top of page here VWP.
I have one in my box-o-bits with corresponding numbers. will it be the same ?
Mr Whippy
posted on 13/2/08 at 02:43 AM Reply With Quote
as far as I'm aware yes it's a standard coding system, but just to be sure it's the same I'd still prise of the cover and have a shifty
u know I really feel like a beer just now but it seems a bit early in the morning, oh sod it I'll have one
[Edited on 13/2/08 by Mr Whippy]
iiyama
posted on 13/2/08 at 07:34 AM Reply With Quote
They are a standard numbering system. The numbers are also on the Relay.
If its broke, fix it. If it aint broke, take it apart and find out how it works!
nitram38
posted on 13/2/08 at 08:35 AM Reply With Quote
The relays normally have a diagram on them so no need to try and get the cover off , Mr Whippy!
David Jenkins
posted on 13/2/08 at 08:50 AM Reply With Quote
You should be aware that there are 2 patterns of connector layout.
This Vehicle Wiring Products page shows it really well.
HTH
(who's just bought a relay off them!)
Doh! Just re-read the original post - with a link to the same VWP page... :blush:
[Edited on 13/2/08 by David Jenkins]
posted on 13/2/08 at 10:09 AM Reply With Quote
yes. beware of the one that has snubber diode fitted since the coil can only bewired one way on those.
britishtrident
posted on 13/2/08 at 12:38 PM Reply With Quote
Maplin are cheaper than the usual places for automotive relays.
Rather than using that type of relay I would use two seperate 4 blade relays.
