Author: Subject: Few more pics from stoneleigh
tegwin
posted on 7/5/08 at 09:30 AM Reply With Quote
Yet another...Stoneleigh photo thread...
Some of the more unusual cars...
Any the pre requisit BBQ shot
www.verticalhorizonsmedia.tv
Agriv8
posted on 7/5/08 at 09:45 AM Reply With Quote
how does that rear setup work then ie no top arm ?
Regards
Agriv8
macspeedy
posted on 7/5/08 at 09:50 AM Reply With Quote
Thats a jag diff, XJ6
posted on 7/5/08 at 09:53 AM Reply With Quote
i got phjot of that - wot you cannot see in these photos is that the steering column is vertical!! and goes though the floor between the driver's feet
r1_pete
posted on 7/5/08 at 09:57 AM Reply With Quote
Thats the Jaguar IRS (Independent Rear Suspension) very popular with hot rodders, I've used several.
The drive shaft also doubles as the top arm and controls camber. In the jag they are mounted in a cage, most rods utilise a fabricated cross member welded to the chassis to carry the diff, and 4 coilovers, you will often see a spanner used as a brace across the two lower inboard wishbone maontings.
I'm contemplating a wire wheel version for the MGB.
r1_pete
posted on 7/5/08 at 10:00 AM Reply With Quote
Usually to a VW Van steering box then rose jointed to the steering rods, sad i can remember building these things in the 70s.....
Agriv8
posted on 7/5/08 at 10:36 AM Reply With Quote
Ahh I see thanks for that
posted on 7/5/08 at 10:45 AM Reply With Quote
That Jag set-up was used for donkeys years on E-Types and many others. In many cases with inboard disc brakes as well. Not light by any means, but reputably strong hence the attraction for the big power hot rodders.
