Author: Subject: Strikers
mookaloid
posted on 29/5/08 at 10:09 AM Reply With Quote
Strikers
Anyone know about Strikers?
I've seen Mk2's and Mk3's advertised - What is the difference?
Is there a guide anywhere - model history etc?
Mark
posted on 29/5/08 at 10:10 AM Reply With Quote
1
speedyxjs
posted on 29/5/08 at 10:15 AM Reply With Quote
Originally posted by 02GF74
1
posted on 29/5/08 at 10:19 AM Reply With Quote
1
mk2 and mk3 differ by 1.
marmot0
posted on 29/5/08 at 10:22 AM Reply With Quote
I am building a striker at the moment, a great choice of car. There is a model which had outboard suspention but can't remember which one, make sure you go for the one with inboard rocker arrangement, also I think the MK2 was contructed of larger gauge steel so a little heavier
mookaloid
posted on 29/5/08 at 10:24 AM Reply With Quote
1
Ok I'll rephrase the question - what are the differences between the cars with those designations?
marmot0
posted on 29/5/08 at 10:34 AM Reply With Quote
I think it was the mk3 that had ouboard suspention, not sure how good that was as they reverted back to the rocker arrangement, which cars are you looking at
JimSpencer
posted on 29/5/08 at 10:40 AM Reply With Quote
Mark
Hi
Know a bit.
Mk1 one striker was basically a one off the first prototype.
Mk2 striker is the one that's the most common, built in various guises since right through to the current RAW striker -which is still essentially a Mk2.
Has inboard front suspension and either an escort based 5 linked back axle or the sierra based IRS.
MK3 Striker was a very short lived 'clubman' version built 1988 - 90, 60 units made.
Featured Chevette based outboard front suspension and the escort back axle, allegedly slightly lighter weight chassis.
The bodywork of the Mk2's and 3's is interchangable, so apart from the front suspension there's no visable difference.
Mk4 is the full bodied car that eventually became the Phoenix and Fury
My car (as avatar) is a Mk3, and it's now apparently quite rare as according to the Sylva Chat room there's not that many Mk3's still about.
mookaloid
posted on 29/5/08 at 11:20 AM Reply With Quote
Thanks guys - good info. There's a Mk3 on ebay at the moment - I hadn't seen one before and it was confusing.
I would have thought that the MK 2 with inboard suspension would have been a better arrangement as it gives rising rate which is better.
mark
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 29/5/08 at 04:00 PM Reply With Quote
Built a Mk2 striker with a v8 rover in it , was a cracking car
JimSpencer
posted on 30/5/08 at 07:47 AM Reply With Quote
mark
Hi
It's a bit Chicken & Egg to be honest.
The Mk3's lighter, especially compared to an IRS Mk2.
Plus there's more space under the front end, and the shocks are out in the air stream and don't get cooked by the radiator
- but the Mk2 has geometry that's easier to adjust, and there's more folk running them so setup info is easier to get at.
However if you're going into Hillclimbing I would suggest that the rest of the spec of the car, and it's condition, is probably more important than the chassis type.
Of the 2 on the bay-of-E at the moment, the Mk3 would tick more of the box's IMHO.
iank
posted on 30/5/08 at 07:57 AM Reply With Quote
I don't think Sylva made any IRS Mk2's, it was introduced as an option by RAW I seem to remember.
[Edited on 30/5/08 by iank]
Anonymous
