Author: Subject: Ford P100
liam.mccaffrey
posted on 15/6/08 at 02:46 PM Reply With Quote
Ford P100
I have a P100 that I want to freshen up and I was wondering if people knew what level of interchangeability there was between sierras and P100's (it is a sierra one not a tina)
The mechanicals and body are surprisingly good but the inside is junk.
Im gonna build a 302 for it while im in the states and use an F150 back axle.
[Edited on 15/6/08 by liam.mccaffrey]
Build Blog
Build Photo Album
redscamp
posted on 15/6/08 at 06:30 PM Reply With Quote
the front struts are longer
the front crossmember is mounted with spacers.
the steering coupler is longer to reach the rack
the front hubs can be swapped for 4 stud car ones no problem
the engine mounts have built in spacers to match crossmember
there is also no rear wash/wipe on wipper stalk
no interchangeabilty problems
on the pluse side you get large diameter anti roll bar
on the minus side you get the smallest vented discs 240mm!??
[Edited on 15/6/08 by redscamp]
