Author: Subject: Another Ebay scam?
speedyxjs
posted on 2/7/08 at 04:11 PM Reply With Quote
Another Ebay scam?
Linky
trogdor
posted on 2/7/08 at 04:15 PM Reply With Quote
I saw those at the NEC classic show. They looked pretty good the guy showed it sparking away etc but i just can't believe it would do as they said on the car so didn't bother
Paul TigerB6
posted on 2/7/08 at 04:18 PM Reply With Quote
Not convinced they work but what makes you think its a scam??
speedyxjs
posted on 2/7/08 at 04:19 PM Reply With Quote
Well is it like all the other 'ideas' for saving fuel like strapping a couple of magnets to your fuel pipe?
trogdor
posted on 2/7/08 at 04:23 PM Reply With Quote
It did have an effect as the stand has this rig set up to show you it working, ie more sparks burning better etc which all worked well on the stand out of the cylinder but in cylinder i suspect under high pressures it would not make much difference
Paul TigerB6
posted on 2/7/08 at 04:26 PM Reply With Quote
Very likely i'd say - cant see it improving a properly operating ignition system. Stick to a decent set of leads and properly gapped good quality set of spark plugs.
SeaBass
posted on 2/7/08 at 04:31 PM Reply With Quote
Oil of Snake
mr henderson
posted on 2/7/08 at 04:32 PM Reply With Quote
It's a bit like religion really, if you think it's doing you good, then it is. So not really a scam (although it is) more a bottle of snake oil.
I'm amazed that they can still base a business on selling carp like this. I see they do the things to put in your fuel tank so you can run engines with soft valve seats on unleaded. What will they think of next?
John
mr henderson
posted on 2/7/08 at 04:35 PM Reply With Quote
How abut some special wax to rub in the sidewalls of your tyres to make them more pliable and therefore the car more comfortable (as well as quieter)
Or a special car aerial that would attract energy every time you cross a ley line, thereby reducing fuel consumption
John
designer
posted on 2/7/08 at 04:40 PM Reply With Quote
These were first advertised twenty years ago.
In the wire a small gap is left which the spark has to jump, just like in a spark plug, but smaller.
The theory is that the charge will increase as it tries to just the gap, just like in a capacitor.
DRC INDY 7
posted on 2/7/08 at 05:18 PM Reply With Quote
Its all a load of tosh many moons ago some guy from some company as you ca tell i have forgot any how did a demo on a aston martin dbsv8 that we had in the garage him saying that by fitting these magic devices same as the ones on ebay the emissions readings from the exhaust would be reduced if i remember rightly 0.01 co which we said yea right so he set about trying to prove us wrong
Guess what it did not work
Puddle Dodgers Club
myke pocock
posted on 2/7/08 at 05:53 PM Reply With Quote
I heard of this idea years ago. It involved using a button, splitting the plug lead and wiring the ends through two of the opposing holes to get the spark to jump. Same idea, just on each lead instead of the coil lead. Cheaper my way to see if it works!!!
Mark Allanson
posted on 2/7/08 at 08:00 PM Reply With Quote
My Grandad used to split the ignition leads on his A35. They had copper leads and you would cut , pare back and attach to opposite holes on a shirt button so the spark jumped causing the capacitance effect. Never mad a sod of difference but he swore by it. At least it was not £25 buy it now!
