piddy
| posted on 21/8/08 at 03:58 PM |
Changing diesel fuel filter on 2.0 tdci
Just changed the fuel filter on my Mondeo diesel. Now it won't start.
Do you have to do any thing like purge the air out? or fill it with diesel?
whitestu
| posted on 21/8/08 at 04:00 PM |
I didn't when I changed the on on my Citroen C8, but obviously a different engine.
Stu
Danozeman
| posted on 21/8/08 at 04:27 PM |
Theyr a b*****d if you dont fill the filter with diesel first as they wont pull the air through. You need to take the filter off and try to fill it
with diesel. Failing that try and borrow a priming pump from someone to pull it through that way. Theyr a right pain as they have no lift pump from
the tank.
You could turn it over and over and it might fire up in the end but i wouldnt advise it as the pump is running dry.
[Edited on 21/8/08 by Danozeman]
Dan
piddy
| posted on 21/8/08 at 04:31 PM |
alll sorted now.
filed it and off she went
