Author: Subject: Sanding down brake shoes?
tegwin
posted on 16/9/08 at 01:52 PM Reply With Quote
The brakes on my classic TVR dont look like they have had much use...However, the drums were removed, thus leaving the shoes exposed....then the car was resprayed..
So, there is a reasonaly thin spatter of primer/sanding coat on the pads..
Would it be perfectly acceptable/safe to simply take some sandpaper to the shoes and remove the paint to get back to the nice clean finish one would expect from a brake shoe?
www.verticalhorizonsmedia.tv
rallyingden
posted on 16/9/08 at 01:59 PM Reply With Quote
Just put it all back together.
The paint wont last long after a few presses of the pedal.
RD
Mr Whippy
posted on 16/9/08 at 02:05 PM Reply With Quote
simply yes, use to be a very common practice in the old days to take the glaze off, also remove the sharp edge of the shoes leading edge if there is one to prevent the corner chipping till it beds in, a sanded chamfer is all that’s needed.
tegwin
posted on 16/9/08 at 02:10 PM Reply With Quote
This is why I love working on an old car like this...
Things are all logical.....
Thanks for the input...will give them a going over before I re-assemble my nice shiny painted backplates
MikeR
posted on 16/9/08 at 02:56 PM Reply With Quote
be careful how much you take off and remember the pads will need bedding in after you've done this (unless you can somehow guarantee to take off the exact amount so they match the face of the brake drum.)
iank
posted on 16/9/08 at 03:09 PM Reply With Quote
Don't breath the dust!
Anonymous
skodaman
posted on 16/9/08 at 05:40 PM Reply With Quote
Fairly fine wet and dry with water works great.
Skodaman
blakep82
posted on 16/9/08 at 06:47 PM Reply With Quote
put it back together, brake pedal on
________________________
posted on 16/9/08 at 07:53 PM Reply With Quote
An old car could still have asbestos brake linings, treat with respect!
