chrsgrain
| posted on 2/12/08 at 07:01 PM |
Stuck master cylinder pistons...
Hi all, as some of you may know, the current project is a restoration.... a TR4...
Just wondered if anyone has any clever suggestions for a problem with my clutch and brake master cylinders... the plungers are stuck and won't
come out.... I can force them into the cylinder, but that has obviously made the whole thing worse... I think they're stuck with brake fluid
residue and possibly some ali corrosion... any ideas how to get them out?? Other thing is that - if they are that bad, should they be replaced
anyway?
Chris
| posted on 2/12/08 at 07:08 PM |
Girling cylinders quite normal for them to stick
Lubricate the bores with brake flud working in by pushing the piston in a couple of times then allow surplus to drain off then very low pressure
compressed air no more than about 15 psi -- blow piston out into a thick cloth wrapped over the end --- don't point the business end of
the cylinder it at yourself or anything of value. And beware splashes of brake fluid -- protect your eyes and paintwork.
clairetoo
| posted on 3/12/08 at 09:50 AM |
I wouldnt even think about using them - they dont cost the earth to replace , and you really dont want them to fail later
Its cuz I is blond , innit
Claire xx
Will weld for food......
| posted on 3/12/08 at 09:52 AM |
he he he ; I had this on a sierra master.
Now this one had a hollow in the end in which the push rod fitted.
I got it out using one of these:
