paul the 6th
| posted on 3/12/08 at 08:41 PM |
a mate of mine has a 2003 seat ibiza with a snapped timing belt/chain - how much to fix?
eyup
A friend of mine has just asked me how much it will be to get the timing belt/chain fixed on his engine... I told him I'm not entirely sure but
that I'd check on here.
If the engine timing needs resetting, would that affect the cost massively? If not, is it as simple as fitting a new belt and that's that?
Thanks in advance
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat
Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
jonesier1
| posted on 3/12/08 at 08:48 PM |
belt snapped
resetting the timing is the simple bit which as you say will need doing before the belt is fitted but the bad news is depending on the engine type,you
have a 99% possiblity that the pistons have meet the valves and are bent so the cly head will need to come off and valves replaced then rebuilt with a
new belt fitted.not cheep.Depends on the engine type...no of valves etc.
marmot0
| posted on 3/12/08 at 09:18 PM |
If engine was running on that engine some valves would have been bent, I guess 500 quid
at a local friendly garage would be reasonable
paul the 6th
| posted on 3/12/08 at 09:27 PM |
thanks for your reply matey, have passed this info onto my friend so he knows what could be involved.
Pressed Clothing...
Omni
| posted on 4/12/08 at 12:27 AM |
If the valves have met the piston(s), the head will probably need a skim too I am affraid!
tomblyth
| posted on 4/12/08 at 05:00 AM |
u2u all the details of the car and engine type I will check if its an interferance engine or not on autodata!
paul the 6th
| posted on 4/12/08 at 10:40 AM |
thanks for the offer tom but I'm working away in reading at the mo & friends car is at his house in west yorkshire... He messaged me on
facebook asking quickly how expensive it would be to sort out, so I told him about the pistons & valves issue just to give him a rough idea of how
big a job it is...
I'll try get in touch with him and get the details to you. I know it's a 54 reg 1.4 seat ibiza basic model type...
Pressed Clothing...
