NS Dev
| posted on 29/12/08 at 01:05 PM |
Bosch Hall effect (and VR) sensor info
Anybody know where I can find out the operating voltages and pinouts for the following Bosch sensors:
Hall effect: 0 232 103 033
VR: 0 281 002 145 3(6)5 515 (the 6 in bkts could be an 8)
I have the basic bosch sensors PDF downloaded from their site, and this does not list either of these sensors.
For the VR its no big deal, they list a very similar one and the worst will be I get the signal and ground the wrong way round, BUT: .... the hall
effect one is trickier, since they do 5 volt ones and 12/24 volt ones! Thye list one with the same part number as mine except with 022 at the end not
033, and that is a 12/24v one, but I don't want to assume that and pop the sensors!
They are the cam sensors on my aprilia engines by the way.
| posted on 29/12/08 at 01:11 PM |
http://www.ignitionleads.co.uk/detailspage.aspx?searchStr=PDTS0344
suggests the hall effect is quite commonly used.
I would have thought a look through the Haynes manual for one of the cars which use it would give the answer.....
I suspect there's a pdf somewhere out there on the 'net.
| posted on 29/12/08 at 01:16 PM |
is too long for a Bosch code.
If you look up
0 281 002 145 you'll find a few options.
Including
http://www.webdealauto.com/-alpeur-de-regime--gestion-moteur/c2159/p243094/-alpeur-de-regime--gestion-moteur--------------------/product_info.html
which suggests they're fitted to Rover 800s...
| posted on 29/12/08 at 03:40 PM |
It looks like the hall effect sensor is used in Volvos and I've got a wiring diagram for Volvo S80 diesels (which use this part). It'll
show the pin-out (if you can be bothered to search through all the drawings to identify the component to refer to the wiring diagram). Won't
tell you whether it's 5v or 12v though....
If you want it let me know and I'll plop it on an anonymous FTP site for you to upload....
NS Dev
| posted on 29/12/08 at 04:35 PM |
If you could it would certainly be worth a shot!
let me know
cheers
Nat
| posted on 29/12/08 at 07:32 PM |
FTP up and running
FTP CLOSED
the files you need are the SUB pdf file and the password text file.
hope it helps...
Ben
[Edited on 30/12/08 by BenB]
NS Dev
| posted on 29/12/08 at 11:50 PM |
thanks, downloading as I write
