Author: Subject: Towbar electrics
mikeb
posted on 12/1/09 at 03:18 PM Reply With Quote
Towbar electrics
Following on from my previous thread.
I am now the proud owner of a large hunk of tow bar type metal from my local german car scrappy £40 and I didn't have to take it off, looks good and has the max towed weight stamps on it. Just need some M10x100 bolts...
The electrics, from what I have found out is if you have bulb failure warnings you need a relay. As I will only use the thing once or twice I can cope with the computer telling me I have a lamp out. Do I still need the £20 relay (and the hassle of getting a 12v feed to the boot)
a4 avant 98 if it helps answer the above
Mike
mark chandler
posted on 12/1/09 at 03:31 PM Reply With Quote
The danger is blowing the module that studies the current draw to decide if you have lost a bulb or two.
IMHO yes, relays are required.
Do you need the correct box, well no, just some cheap relays like these and a soldering iron.
You are supposed to have a warning when indicating, buzzer or light. Buzzer annoyed me so filled with glue !!!
Regards Mark
mikeb
posted on 12/1/09 at 04:33 PM Reply With Quote
Think you might be right, I have read on the vwaudi forum it can nagger the module and show failed bulbs all the time!
Anyone got a 7 way relay they dont need?
