Author: Subject: Volvo Locking wheel nuts NOW SORTED!
liam.mccaffrey
posted on 17/2/09 at 07:59 PM Reply With Quote
Some numpty has impact wrenched them on and the last person to try to remove them has all but destroyed the key. I got one off but the key is all chewed up.
There appears to be a steel sleeve on the nut to fill the gap between the nut and the wheel recess so I'm not sure i could get an old socket over the top.
Does the drive round the car park with the other nut loose really work?
[Edited on 20/2/09 by liam.mccaffrey]
Build Blog
Build Photo Album
locoboy
posted on 17/2/09 at 08:18 PM Reply With Quote
I remove locking wheel nuts without the key most weeks at work.
I tackle those with the free floating sleve like this.
Chisel off the rotating sleve NOTE: wear goggles as these are often made of extremely hard steel that is resistant to drilling and can quickly take the edge off the cold chisel.
Then once the outer sleve is removed its time for the lump hammer and cold chisel again and up to an hour of hammering if they have been doen up tight!
I find it works best if you do up VERY tight the other nuts so it stands a chance of pulling the wheel in that fraction and releasing the pressure on the locking nut.
I hope this is of use to you.
Locoboy
posted on 17/2/09 at 09:20 PM Reply With Quote
Are wheel nuts weldable? Can't you just weld a normal wheel nut onto the locking one and then attach with a breaker bar? Sounds like the old locking nuts are FUBARd anyway....
24vseven
posted on 17/2/09 at 09:34 PM Reply With Quote
i one welded bolts onto some bmw bolts to get them off
my dad has a c70 conv and had the same problem they were the maggard type he bought a job lot of keys and spent ages grinding bits off them till he had one that worked
posted on 17/2/09 at 09:51 PM Reply With Quote
I always end up with the job of removing locking wheel nuts! Do as locoboy says , you need to get a nick in the nut then angle the chisel around 45 degrees so that your knocking the nut anticlockwise . With practise it's easy. Locking nuts tend to be made of very hard steel , have never managed to get really good penetration when welding a nut on. Stick welder on high setting may work?
24vseven
posted on 17/2/09 at 10:14 PM Reply With Quote
we used stick welder up high
as regards chiseling dependant on the wheel somtimes the bolt is well recesed like in my dads case so there was no room to get in to chisel
posted on 18/2/09 at 08:08 AM Reply With Quote
There are sockets tha look like they have an internal left hand thread to remove wheel nuts - think I saw them in the latest Machine Mart catalogue.
liam.mccaffrey
posted on 18/2/09 at 06:47 PM Reply With Quote
currently I have tried impact driver, impact wrench.
Have the left hand thread thingy coming tomorrow. I will try chisselling (sp) the sleev and nut tomorrow.
I have 3 of these buggers to do
Build Blog
Build Photo Album
posted on 18/2/09 at 07:24 PM Reply With Quote
The left hand thread thingys need an impact driver to work ---
liam.mccaffrey
posted on 18/2/09 at 07:36 PM Reply With Quote
good to know BT thanks. Just bought a better one as the old one is poo
Build Blog
Build Photo Album
posted on 18/2/09 at 08:43 PM Reply With Quote
If the locking wheel nuts have the rotating ring around the outside they are useless. , the ring has to be removed first and then its normally easy with a chisel .
James
posted on 18/2/09 at 11:43 PM Reply With Quote
I bought something for this once called a Gator Socket or something.
It's a a deep socket about 22mm diameter that is filled internally by sprung pins.
As it's pushed onto the nut, the pins clamp around the knackered nut.
It cost about £20 including the ratchet.
Might be worth looking at. Think I got it from B&Q.
HTH,
James
liam.mccaffrey
posted on 20/2/09 at 06:27 PM Reply With Quote
Well after about 4 days of blood sweat tears and cursing we got the last one off.
We attacked the rotating ring for hours and just couldnt get it to break. Mashed it good and proper though and stopped it from rotating which helped us later.
basically we deformed the female socket on the stud and hammered the key on for all it was worth. We then got a 7' long piece of 4"x3" timber and using a kerb levered the the back of the socket whilst putting the torque on with the breaker bar. This coupled with the completely mashed socket stopped the key from coming out and riding over the rounded corners.
Thanks for all your suggestions guys many thanks!
Build Blog
Build Photo Album
posted on 20/2/09 at 08:18 PM Reply With Quote
Brute force wins again.
