Author: Subject: Where to get precision measuring equipment
tegwin
posted on 24/11/09 at 09:34 AM Reply With Quote
I have been asked what I want for Christmas..
As I dont really have any idea I thought I would ask for some precision measuring equipment..
Some micrometers, depth guage, decent vernier etc...
Obviously these are reatviely expensive so I have no idea how many people will be willing to buy me....
However, can anyone suggest what size micrometer etc I should be looking at,
What brand is going to be good and well made?
And where is best to get them?
www.verticalhorizonsmedia.tv
flak monkey
posted on 24/11/09 at 09:45 AM Reply With Quote
Mitutoyo make some of the best measuring equipment that will last a home user forever. Kennedy also make some good stuff as do Moore and Wright.
Mics come in 25mm increments, 0-25 and 25-50 is are the most useful.
Any vernier will have a depth gauge on which will be more than good enough for most jobs. You can get depth mics as well, again in 25mm increment.
I would avoid buying secondhand if you want it to be accurate
Sera
http://www.motosera.com
posted on 24/11/09 at 09:46 AM Reply With Quote
Machine mart - the micrometer and dial gauge looks ok and work well.
Maplins have on special offer ever once in a wile a digital verier - nice to have but useless if batteries go. I have one and may even have a gigital micrometer but use the manual ones as they are quicker and do not rely on batteries.
0-25 mm micro and 25-50 mm .
Add to you list a set of steel rules: 159 mm, 300 mm and 1 m
tegwin
posted on 24/11/09 at 10:01 AM Reply With Quote
Was going to ask where to get them, bt the Mitutoyo website uk seems to sell them direct..
Now all I have to do is decide if I want a friction stop or a ratchet stop... Anyone care to suggest which one is most consistent and reliable?
When I did my machine training most of the ratchet heads had been snapped off or didnt work anway....
[Edited on 24/11/09 by tegwin]
SteveWalker
posted on 24/11/09 at 12:21 PM Reply With Quote
From experience the Maplin digital verniers eat batteries and are frequently dead when you need them, whereas the Mitutoyo's will run for years at a time on the same batteries and give decent warning of needing replacement.
RAYLEE29
posted on 24/11/09 at 12:38 PM Reply With Quote
Its more about feel in reality as if you do a ratchet or friction quickly it will show a smaller size than if you go slowly
mind you were only talking tenths of a thou so just how accurate do you need to be?
also remember they are only correct if set to a standard at 20 degrees c and use at the same but again only talking tenths of a thou
Ray
posted on 24/11/09 at 12:41 PM Reply With Quote
My Mitutoyo vernier is now approaching 20 years old, and has worked consistently well. Only needed 3 or 4 batteries in all that time (common hearing aid cells).
As a comparison with the cheapy ones, the stated battery life on mine is something like 12 months if you're good at turning it off when not using it, or 6 months if you leave it on!
This matches my own experience.
Mal
posted on 24/11/09 at 12:42 PM Reply With Quote
I have used with company before:
H Roberts Metrology
www.hroberts-di.com
Marcus
posted on 24/11/09 at 12:47 PM Reply With Quote
If you look on the Cromwell tool swebsite, they usually have special offers on measuring stuff. IMO avoid the Oxford scientific stuff, it's a bit cheap. Mitutoyo is the way forward, although cromwells own kennedy verniers are rebadged Mitutoyo.
Marcus
Because kits are for girls!!
