mackie
| posted on 13/8/04 at 11:22 AM |
Adjusting valve clearance on a Fiesta
I'm about to attempt to service my girlfriends J reg Fiesta 999cc (or is it 998cc) banger. I'm not sure which exact engine it in but
it's not the HCS but it is Kent-like.
I think I should probably look at the valve clearances (along with putting see-thru oil in it )
My question is, how do I check and how do I adjust them? This is something I've never done before.
I'm guess someone can give me some clues since it can't be that different to doing it on an Xflow.
Mackie.
Donners90
| posted on 13/8/04 at 11:29 AM |
Does it look like this??
If so it is most likely a Valencia engine! Let me know and I'll have a look for the procedure!
If you could let me know (2u2) the reg number I might be able to narrow it down
[Edited on 13-8-2004 by Donners90]
mackie
| posted on 13/8/04 at 11:45 AM |
Donners,
It does look rather like that. It's a 1l rather than a 900 or 1.1. I'll u2u you the reg asap.
Donners90
| posted on 13/8/04 at 12:00 PM |
Dammit
Seems like the Ford TIS doesn't go back as far as that. I can get part nos etc through microcat, but no procedures! I can email you a procedure
for 1.25 zetec if that helps!!??
Sorry
theconrodkid
| posted on 13/8/04 at 12:15 PM |
mackie,you know how to adjust tappets?do one cylinder at a time(turn engine till inlet valve closes and add a few degrees for luck,feeler gauge
between rocker and valve stem,11mm socket on adjusting bolt till it just nips feeler,easy peasy
who cares who wins
pass the pork pies
mackie
| posted on 13/8/04 at 12:20 PM |
What you just said does make sense, I've just never done it before. I'll whip off the rocker cover and have a looksee. It does sounds
fairly simple.
How would you suggest turning the engine? Leave it in gear and turn the front wheels?
garage19
| posted on 13/8/04 at 12:23 PM |
If you are going to do that, taking the plugs out makes life easier.
marktigere1
| posted on 13/8/04 at 02:39 PM |
My MK1 Fiesta 1.1 used to 'tick' before AND after adjusting the tappets.
I think it was part of the design
If a bolt is stuck force it.
If it breaks, it needed replacing anyway!!!
(My Dad 1991)
mackie
| posted on 13/8/04 at 02:42 PM |
I think it's meant to, to a point.
Actually my girlfriend's car isn't that bad but I thought I'd at least check them as a matter of course. It's just one of
those sewing machine engines I guess
marktigere1
| posted on 13/8/04 at 02:52 PM |
They are a bit like a sewing machine.
Always liked the induction noise they made.
Mind you, engine did 100,000 miles with me and the bodywork finally gave up at 158,000
Miss its simplicity as well.
Mark
(My Dad 1991)
mackie
| posted on 13/8/04 at 03:00 PM |
Did you find it drank a lot of oil?
marktigere1
| posted on 13/8/04 at 03:34 PM |
Not really no.
Only problems I did notice on the oil front was on short journeys. Used to get loads of the white mayo in the breather/oil fill bung.
With long journeys I never had a problem.
Only let me down once when I failed to change the water pump in time. It failed at 70mph on the A1. (My spare was on the back seat as it had been
making a noise for several weeks.) Totally my fault not the engine
Mark
(My Dad 1991)
theconrodkid
| posted on 13/8/04 at 03:37 PM |
jack one front wheel off the ground ,put it in top gear and turn the wheel,tis easier with plugs oot
who cares who wins
pass the pork pies
mackie
| posted on 13/8/04 at 03:44 PM |
If I can turn a Rover V8 with the plugs in with by bare hands on the flywheel I think I can manage a piddly little fiesta engine
Thanks for the advice all.
PS. I wondered what the crud in the filler was... actually... what *is* it?
marktigere1
| posted on 13/8/04 at 03:59 PM |
Its an emulsion formed when Oil and water mix.
The water comes from condensation in the engine on short journeys. Long journeys and the water just evaporates.
Mark
(My Dad 1991)
mackie
| posted on 13/8/04 at 04:12 PM |
You learn something new every day
My girlfriend tends to use it on mostly short runs which probably isn't so good but since I can get another car for next to nowt I don't
really mind if it's not treated brilliantly.
jollygreengiant
| posted on 15/8/04 at 10:21 AM |
Valve on the rock. is the way.
turn engine until inlet & exhaust on a cylinder are just between closing exhaust & opening inlet, then adjust opposing cylinder tappets ie 1
rocking adjust 4, 2 rocking adjust 3, 3 rocking adjust 2, 4 rocking adjust 1.
hope this helps.
enjoy.
stephen_gusterson
| posted on 15/8/04 at 10:52 AM |
rule of nine isnt it? if 4 is fully open adjust 5, if 8 then adjust 1....
afair
I had a (old git anecdote coming on here) 1978 fiesta 950 van that I bought of my company in 1980 with 24k on it for 510 quid (bargain even at the
time!)
I took it to 95,000 mostly motorway miles. It was still on the same (barely legal) tires - honest! Clutch was on way out.
Only thing that went wrong was a crack between two valve seats, that was cured in a day by taking it to a shop where they welded it and put in valve
inserts and lapped em in for me.
atb
steve
mackie
| posted on 15/8/04 at 12:52 PM |
At the moment I'm having the much more mundane problem of getting the damn oil filter off. I might have to swallow my pride and just get a
garage to do it as I can't budge it.
Browser
| posted on 15/8/04 at 12:58 PM |
Put a drip tray under it, hammer a large (i.e. non-bendy/hefty) screwdriver through it and unscrew it that way Does work, had to do it myself a few
times
| posted on 15/8/04 at 03:14 PM |
Bloody heathens!!!!
Get a strap wrench you tight git . £1.99 on most car boots round here.
mackie
| posted on 15/8/04 at 03:51 PM |
Tried the strap wrench but there's not enough room to really move it. Will try the screwdriver technique
Mark Allanson
| posted on 15/8/04 at 08:12 PM |
afair
time!)
atb
steve
Rule of nine only works on 1342 engines, the kent/valencia/ECS engines are 1243(?).
JGG has got for these engines
