mikeb
| posted on 3/1/12 at 01:19 PM |
Bathroom Tap Leaking - Where to get spares
I have these
http://www.homebase.co.uk/webapp/wcs/stores/servlet/ProductDisplay?langId=110&storeId=10151&partNumber=125531
homebase store said they don't do spares and weren't helpful.
Any one know where to get a replacement cartridge thingy.
Mike
RichardK
| posted on 3/1/12 at 01:24 PM |
Buy them again,swap the cartridge and take back as faulty,easy if you've few morals like me!
Love
Rich
Gallery updated 11/01/2011
jossey
| posted on 3/1/12 at 01:28 PM |
+1 then delete this posting lol
David Johnson
mikeb
| posted on 3/1/12 at 01:34 PM |
nice!
Depends on my mood!
Any other options? sure a catridge is only a tenner
designer
| posted on 3/1/12 at 01:47 PM |
My Alcatel phone bought for a fiver, when mine disappeared in UK, accepts SIMS worldwide!!
John P
B & Q do replacement cartridges such as at
http://www.diy.com/nav/fix/plumbing/washers-tap-replacements/taps/Plumbsure-Ceramic-Tap-Glands-8mm-Spline-12-7mm-2Pk-11477999
I found it best to take the old one out and take it with you as lengths etc can vary.
You also need to make sure the old handle fits OK as I did one where the fixing screw was too short and the female thread in the new cartridge a
different size.
John.
Chippy
| posted on 3/1/12 at 01:48 PM |
Suggest that you try your local plumbing store, Homebase are absolutely useless with regards getting spares for anything they sell. We purchased a set
of taps with ceramic inserts/seats and our local plumbing shop had exactly the correct parts. Worth a try. HTH Ray
Never thought of using B & Q but will next time, definately cheaper!
[Edited on 3-1-12 by Chippy]
Xtreme Kermit
| posted on 3/1/12 at 02:33 PM |
+1 on the local plumbers merchant and take your own one along.
The thing I found when I got new inserts for the kitchen mixer was that the ceramic valve was absolutely fine, but the selection of O-rings had gone
hard and were leaking. Of course I only found this out when I had installed the new ones and was carrying out a post mortem...
Edit to correct speeling
[Edited on 3/1/12 by Xtreme Kermit]
PAULD
| posted on 3/1/12 at 07:37 PM |
If you have access to a lathe, I've fixed mine by skimming about half a millimeter off of the main shoulder and the end of the cartridge. this
puts more load on the end seal.
fazerruss
| posted on 3/1/12 at 09:15 PM |
the taps on my sink in the gararge are almost identical to them and were only about 20 quid from tool staion
http://www.toolstation.com/shop/Taps+Showers/Bathroom+Taps+Mixers/Contract+14+Turn+Taps+Basin/d240/sd2691/p58728
"if assholes could fly this place would be an airport"
