Author: Subject: concrete fence posts
theconrodkid
posted on 10/3/12 at 01:06 PM Reply With Quote
ok clever people,i have some concrete fence posts going up,at one end i want to put a gate,so,can i drill and rawlplug the hinges onto the concrete or should i put a wooden post up?
who cares who wins
pass the pork pies
designer
posted on 10/3/12 at 01:10 PM Reply With Quote
If they are well concreted in place they will take a gate, the only problem will be getting a plug into the post without hitting rebar.
snapper
posted on 10/3/12 at 01:25 PM Reply With Quote
Another way is to wrap steel plate around the concreat and secure wood in the recess then screw hinges to it
I eat to survive
I drink to forget
posted on 10/3/12 at 01:33 PM Reply With Quote
Having drilled concrete fence posts, I'd recommend using an SDS drill and fitting the hinges to the post.
Phil
Chippy
posted on 10/3/12 at 03:24 PM Reply With Quote
John if they are the rebated type posts that fence panels fit into, then another way to do it is fix a timber into the unused rebate with a big enough section to screw your hinges onto. HTH Ray
theconrodkid
posted on 10/3/12 at 04:44 PM Reply With Quote
cheers for the replies peeps,Ray that is what i had intended to do,all i need now is an sds drill....oh and a kango to break up some concrete that is in the way
who cares who wins
pass the pork pies
jacko
posted on 10/3/12 at 05:01 PM Reply With Quote
Sikaflex the timber in ?
theconrodkid
posted on 10/3/12 at 08:20 PM Reply With Quote
doubt silkaflex would do it,last time the big bad wolf blew on it,6 inch nails couldnt hold it together
who cares who wins
pass the pork pies
