Author: Subject: Who knows an online sikaflex supplier
mangogrooveworkshop
posted on 8/3/06 at 04:44 PM Reply With Quote
Looking for sika data from a local supplier
ned
posted on 8/3/06 at 04:56 PM Reply With Quote
decorating direct sell an equivalent sikaflex product..
Ned.
http://www.decoratingdirect.co.uk/viewprod/s/SIRPF15LM/
[Edited on 8/3/06 by ned]
beware, I've got yellow skin
posted on 8/3/06 at 06:24 PM Reply With Quote
I'll 2nd Ned on that one, good product, good price and quick delivery - I'm on my 4th tube so far
mookaloid
posted on 8/3/06 at 06:59 PM Reply With Quote
Car Builder solutions?
posted on 8/3/06 at 08:44 PM Reply With Quote
Whatever you do, replace "sikaflex" with "PU adhesive/sealant" when you search.
there are many PU sealants that do a good job and are much cheaper.
wicket
posted on 8/3/06 at 09:24 PM Reply With Quote
Got mine from RS. Its Loctite 5220, 5221, and 5222, this is 3 different colours black, grey & white; p/n 313-8653, 8669 or 8681 £5-71/tube. It can be kept for several days once opened by removing the nozzle, cover the open end of the tube with a piece of al.al foil & replace the nozzle (clean the nozzle 1st ready for use). As with most adhesive its best to degrease (alcohol based) the mating surfaces before use.
Spec sheet attached
macspeedy
posted on 9/3/06 at 11:36 AM Reply With Quote
Spec sheet attached
Thanks all I will go with the loctite version as I can sleep easy. The locost versions are ok for most applications but for the application we have in mind it has to stay put.
