Author: Subject: Genny size required ???
Deckman001
posted on 8/3/06 at 08:22 PM Reply With Quote
Hi all, what sized genny will i need to power a 130 amp mig which normally plugs into the house ring main ??
Jason
Browser
posted on 8/3/06 at 08:24 PM Reply With Quote
Dunno whether you'd get a genny to do this mate, if you did it'd have to be quite hefty as the start currents on welders can be quite high.
posted on 8/3/06 at 08:25 PM Reply With Quote
a big one! At a guess, (since ive blown 13amp fuses with mine) peak draw is at least 13amps, hence around 3-4kws.
You can get generator/welder combinations, not cheap though.
on machine marts site, there is a 5kw generator for around £600. However, the petrol powered welder have 13hp/20kw output! Thats nearly £2k though. Maybe my sums arent enough.
[Edited on 8/3/06 by JoelP]
Deckman001
posted on 8/3/06 at 08:27 PM Reply With Quote
A friend of mine has a 5kva one for his welder, but I'm not sure what size his welders is, it is on the big size but it's burried at the back of his garage so we can't get to it for a while
Jason
Deckman001
posted on 8/3/06 at 08:28 PM Reply With Quote
Am thinking of hiring a genny to get a bit of welding done on the car
Jason
NigeEss
BIG !
In the region of 3kw.
posted on 8/3/06 at 08:29 PM Reply With Quote
edited above ^
Deckman001
posted on 8/3/06 at 08:30 PM Reply With Quote
Like this then ?? http://www.hss.com/g/41105/Generator_4kva_Long_Tank_Petrol.html
Jason
posted on 8/3/06 at 08:31 PM Reply With Quote
depends what you're welding i guess, specifically the settings.
Deckman001
posted on 8/3/06 at 08:33 PM Reply With Quote
Harness mounts, and throttle pedal mounts ?? so nothing major
Jason
quattromike
posted on 8/3/06 at 09:12 PM Reply With Quote
I would say 4Kva would be ample.
But I'm no sparky
I will say I run a 150amp tig welder from a 110v 3Kva tranny in my garage. So if i can do that then surly you could get a mig to run from a 4Kva jenny
Mike
Deckman001
posted on 8/3/06 at 09:23 PM Reply With Quote
Perfik guys, many thanks
Next job sorted !!
Jason
