Author: Subject: 8 meg broadband -- think twice.
posted on 23/5/06 at 07:33 AM Reply With Quote
Most ISPs apart from cable providers are offerreing the BT ADSL Max 8 mbs broadband as an upgrade - but if you are already on a stable fast connection I would strongly advise thinking twice before taking up the offer.
A lot of people have had major problems since upgrading as a result ISPs are swamped by complaints, to which BT Whosale are playing hard ball trying to ignore and are pressing ahead with exchange conversion even though it is apparent something is going very wrong.
Here is my experience ---
Until ordering the upgrade I was on a stable 1mb/s connection, when ordered the upgrade I was put on a 2 mb/s connection while awaiting my local BT exchange to be upgraded. This connection performed flawless giving download rates close to the maxiumum possible, then disaster struck BT upgraded the exchange my down load rates plummeted first to 550 kb/s then to 56k/s, since complaining to my ISP speeds have increased I have seen a maxiumum of 2,780 mb/s which is around what I expected but average varies widely between 550 and 1770 mb/s and the real world down load rates are probably slower than my previous 1mb/s connection.
My advice is if you are on a 2 mb/s or faster connection that is stable and works well don't upgrade, if you are on 1 mb/s think very carefully before going ahead.
With a 512 mb/s connection it should be worth while.
[Edited on 23/5/06 by britishtrident]
RazMan
posted on 23/5/06 at 07:50 AM Reply With Quote
I have just upgraded to 8 Meg from 2 Meg with Talktalk (their recently publicised broadband & free telephone calls package) I have yet to see any improvement in download speeds.
As a matter of interest, what test prog do you use to measure the download speeds?
Raz
the_fbi
posted on 23/5/06 at 07:54 AM Reply With Quote
A lot of this doesn't make sense...
2Mb/sec would have given you around 232Kb/sec, so not sure what you actually had, given you had more than 550, then you dropped to 550, then to 56. You wouldn't have had 550 or above unless you had way more than 2Mb/sec in the first place.
Your starting point clearly wasn't what you think it was so don't really know what to make about the rest.
This doesn't make a lot of sense either in terms of the numbers you are using.
If your previous 1mb/s (1Mb/sec) connection was giving you more than 118KB/sec then it probably wasn't 1Mb anyway.
Would be nice to know the correct numbers/units for what you were/are seeing.
bimbleuk
posted on 23/5/06 at 08:07 AM Reply With Quote
Just changed to Nildram to get an upgrade from 2Mbit to 8Mbit. there was no guarantee that the local exchange will reach that speed and also was told BT take 5-7 days to profile the exchange, during which the connection speed will vary.
So far I'm getting a stable 450k/s on downloads and the connection speed is 5Mbit+ but that is probably limited by my 1/2 kilometer wireless connection to a mates hoouse as we both share the line
[Edited on 23/5/06 by bimbleuk]
Gav
posted on 23/5/06 at 08:25 AM Reply With Quote
One of the main reasons is adsl is limited by how far you are away from the exchange, you will only be able to reach the full 8mbit if you are within a few 100 meters of the exchange!
With people expecting the full 8mb and complainning like hell, some of the isps are breaking the specs and trying to give you as fast as a speed as possible, this means the line will be unstable.
I'm recieving 4mb from Bulldog which is pretty impressive given the fact the BT said that the most i could get was 1mb if the lineloss was to stay within spec!.
I wouldnt say my ADSL line is unstable but it certianly isnt as stable as when i was with another ISP on 1mb.
However that said with the old isp i had not one single problem, with bulldog im getting lines drops once a week.
The main problem now is that somepeople who ring our phone just carnt get through, mind saying that it is the mother-in-law
posted on 23/5/06 at 09:18 AM Reply With Quote
a few different test are around the web
Adslguide.org.uk http://www.adslguide.org.uk/tools/speedtest.asp
BTs own
http://speedtester.bt.com/cgi-bin/home.page.pl
posted on 23/5/06 at 09:22 AM Reply With Quote
From official BT Speed tester site
BT would regard the speed ranges shown below as normal service:
For 250kbps End Users speeds between 50 - 250kbps.
For 500kbps End Users speeds between 100 - 500kbps.
For 1000kbps End Users speeds between 200 - 1000kbps.
For 2000kbps End Users speeds between 400 - 2000kbps.
phoenix70
posted on 23/5/06 at 10:44 AM Reply With Quote
I think your terminology is a little mixed up, the BT site quotes the rate in KiloBITS per second (kbps), but the_fbi thinks you mean download rates are displayed in IE when downloading a file, that's in kilobytes per second (KB/s).
I would however agree with you the ADSL Max is a risk, but I definately wouldn't put people off using it. I currently have a 1Mb connection and am waiting for ADSL max to improve (too far away from the exchange for more the 1Mb).
PS. Just a thought for anyone having problems with their ADSL, you should check if the Bell wire is wired up in you house (the third wire in the BT socket). I had major problems with the ADSL dropping, after disconnecting the bell wire, no problems at all.
chockymonster
posted on 23/5/06 at 10:54 AM Reply With Quote
I've had a stable 2MB zen connection for the last 2 years. I've recently upgraded to ADSL MAX and am regularly seeing download speeds of 550k a second peaking at up to 700k.
I'm happy, the line is stable and my MSR is 2MB so anything under that can be logged as a fault with BT.
stevebubs
posted on 23/5/06 at 12:25 PM Reply With Quote
I get 2,3M from my Bulldog connection but I've about 3-4x as far away from the exchange as you.
No problem with line drops. Hop onto the Bulldog forums- theres quite a few tips to resolve this sort of problem.
andyharding
posted on 23/5/06 at 12:26 PM Reply With Quote
We upgraded all of our customers to MAX free-of-charge.
Apart from one or two issues to start with everyone is now reporting much improved download rates.
Depending on how busy my local exchange is I can get over 5Mbps from our tester http://www.inetc.co.uk/speedtest/
andyharding
posted on 23/5/06 at 12:30 PM Reply With Quote
Worth noting that there is a 14 day training period when you regrade to MAX while your line learns how fast it can run at so some instability at first should be expected.
Also note the difference between Mbps (megaBITS) and Mb/s (megaBYTES).
A transfer rate of 1Mbps is equal to 0.128Mb/s i.e. divide Mbps by 8 to get Mb/s.
OX
posted on 23/5/06 at 05:04 PM Reply With Quote
a couple of m8s have it for gaming and they wished they had stayed with the 2meg,its been 6 weeks and the line still hasnt stabled
posted on 23/5/06 at 05:14 PM Reply With Quote
I had a line test thinking about 8mb but despite being within a 1/2 mile of the exchange my test result was 5.5mb max.
Personnaly I didnt see much difference moving from 1 to 2mb so I'm just looking for the best 2mb deal I can find.
Anyone know when ADSL2+ will be with us?
Confused but excited.
posted on 27/5/06 at 11:11 PM Reply With Quote
I have a 2M ADSL connection with Onetel as my ISP. Costs £19.99 per month, with unlimited downloads. I am approx. 3K from the exchange and have had no problems at all. Well I did have one, but it turned out to be my fault anyway.
The main factor in choosing them, is that if I phone them someone answers straight away and technical back-up is a normal call, not 50p or £1.00 / minute.
For a computer illiterate like me this could save me a fortune.
