Author: Subject: Whitworth eye bolt
posted on 26/5/06 at 08:04 AM Reply With Quote
Whitworth eye bolt
Here's an odd question - does anyone know where in the UK I could buy a steel eye bolt with 7/8" Whitworth thread at the end?
In case you're dying to know the answer : the correct way to lift a Colchester Student lathe is to screw such an eye bolt into a hole provided, giving a perfectly balanced lifting point.
I could make one, but I'm not confident enough of my engineering skills to lift a 1/2 ton lathe at just one home-made point!
paulf
posted on 26/5/06 at 08:18 AM Reply With Quote
I would try a local machine tool dealers, they usually have that type of thing.I would just get a decent 1/2 inch set screw and weld on an eye made from a bit of 50mm bar bored out to maybe 30mm and 12 mm thick .Weld it using an arc set with lots of amps then let it cool slowly and im sure it will be fine.
Paul
posted on 26/5/06 at 09:11 AM Reply With Quote
I was thinking of getting some 7/8" steel bar, making a thread at one end, and asking the local blacksmith to make a loop at the other end. Welding the end should fix it.
Still not sure about trusting my own welding in this instance - the lathe is heavier than my Locost!
Donners90
posted on 26/5/06 at 01:21 PM Reply With Quote
http://www.certex.co.uk/dox/sup/lh/eyebolts/fmeb.html
or
http://www.angliahandling.co.uk/acatalog/AHS_Online_Catalogue_Collared_Eyebolts___BSW_Thread_46.html
posted on 26/5/06 at 01:30 PM Reply With Quote
That'll do nicely, Sir!
Thanks,
posted on 30/5/06 at 07:50 AM Reply With Quote
I looked at the second supplier - eye-bolt £7.48p + VAT... OK, not unreasonable. Went through the ordering and checkout bit... P&P £25!! Oh - then VAT on the whole lot...
Don't think I'll bother to order it from there...
P.S. I just found another supplier who'll send one for £4.50 P&P. Maybe I'll go there instead...
[Edited on 30/5/06 by David Jenkins]
flak monkey
posted on 30/5/06 at 08:09 AM Reply With Quote
If I had been at work I would have got you one from there. We often get several that fail the visual inspection and get chucked out. Would be fine for lifting half a ton though since they are rated to 2tonnes as std!
Sera
http://www.motosera.com
posted on 30/5/06 at 08:20 AM Reply With Quote
I can't imagine that any modern works would have a 7/8" Whitworth eye bolt!
It has to be that thread 'cos there's a tapped hole in the lathe bed.
Thanks anyway,
flak monkey
posted on 30/5/06 at 08:26 AM Reply With Quote
You would be suprised what we have laying around! Been on the same site for over 100 years. And still regularly have old products come back which are over 50yrs old for a service and still need to be hoiked about on a hoist.
Anywho if you dont manage to find anything. I will have an ask around. Might be something laying about.
Either that or you could always make up an adapter to screw into the lathe bed, then to screw a metric eye into. Make it out of decent steel and it will be fine.
[Edited on 30/5/06 by flak monkey]
Sera
owelly
posted on 30/5/06 at 10:30 AM Reply With Quote
I will probably have one at work. I'll check when I'm back in on Thursday night. I think there is one screwed into the top of the lathe......
http://www.ppcmag.co.uk
RoadkillUK
posted on 30/5/06 at 01:53 PM Reply With Quote
Can't you drill out the old thread and rethread it using Metric?
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
posted on 30/5/06 at 02:01 PM Reply With Quote
It would have to end up around 1" dia thread - and I'm not Desperate Dan!
It looks like what I want is fairly common, so I'll leave it alone and get the right tool for the job.
cheers,
NS Dev
posted on 31/5/06 at 07:35 AM Reply With Quote
Thanks anyway,
Heh heh we have tonnes of whit stuff here!!!! A steel mill built in the 1950's and 60's is held together with the things!!!
If you struggle from elsewhere let me know, we should have a 7/8 eyebolt in stores, at the small end of stuff for here but should have one.
